FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 13 Feb 2010 (Saturday) 20:04
POLL: "Which do you prefer?"
Pulling several exposures from 1 RAW
24
41.4%
Shooting multiple jpegs in camera
34
58.6%
58 voters, 58 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
HDR from 1 RAW vs Multiple jpegs
Supra_t
Feb 13, 2010 20:04 |  #1
Just wondering which you guys prefer.
Creating several different exposures from one RAW file
or
Firing off multiple jpegs in camera.
James Cause Photography
[Flickr (external link)] [LIke me on facebook (external link)]
Gary ­ McDuffie
Feb 13, 2010 20:07 |  #2
Prefer? You can't make a real HDR from only one shot.
Gary
"I'm not much of an artist, but I like to document certain things that I see."
5DII, 7D, some L, Manfroto one and three legged devices, shooting & learning bit by bit via POTN
Supra_t
Feb 13, 2010 20:56 |  #3
Gary McDuffie wrote in post #9604704 (external link)
Ok so you obviously prefer multiple shots in camera. What if not everything in the frame will stay still long enough to fire off 3,5 or 7 shots or as many as you use.
lankforddl
Feb 13, 2010 21:10 as a reply to  @ Supra_t's post |  #4
Three RAW shots! That stinkin' JPEG conversion always destroys the fine details. I like to take one RAW shot and make a -2, and +2 exposure change with DPP then layer them in CS4.
Do a large "print" of a 3 JPEG HDR and this is where the deficiency reveals itself in my opinion.
5DIICAN17-40CAN50CAN85CAN100CAN135CAN70-200
Kevin
Feb 13, 2010 21:32 |  #5
5 Shots raw, 1 stop steps, always. I never shoot jpg, 8-bit files, yuk;):lol:
windpig
Chopped liver
Feb 13, 2010 21:58 |  #6
Dead heat at this point. That's funny. Gotta have multi exposures.
Go ahead, spin the wheel.
terrencemichael
Feb 14, 2010 01:27 |  #7
Hi new man on the scene, Russel Brown gives an excellent example of one photo in RAW for an hdr where there is a lot of movement , for movement this seems to be the best way, however I have done beach and where motor way is involved eg a city in multiple shots and not to bad, my problem is now I want to do night shots in hdr any advice on this one thanks , terrencemichael
dugcross
Feb 14, 2010 10:24 as a reply to  @ terrencemichael's post |  #8
Neither! Got to use at least 3 RAW exposures for HDR. Using 1 shot and trying to make it HDR is NOT HDR it's faux hdr. You cannot create HDR out of one photo!!! You cannot get the details out of one photo to make a HDR. You HAVE to have the over exposed shots and the underexposed shots to do this. If you're using one shot, you don't have a HDR.
Doug Cross
Graphic Designer and Photographer
www.crossphotographics​.com (external link)
Supra_t
Feb 14, 2010 10:57 as a reply to  @ dugcross's post |  #9
Ok so would I import the RAWs straight into photomatix or do you proccess them into a TIFF or something first?
dugcross
Feb 14, 2010 11:07 |  #10
Supra_t wrote in post #9607313 (external link)
Myself I take the RAW files straight into Photomatix before I do any processing. Photomatix actually request you to use RAW files because of the information enclosed.
Doug Cross
Feb 14, 2010 11:16 |  #11
I prefer to use multiple raw images with a wide range of AEB.. Don't use JPG's as the information is lost in the compression.. I only use single shots when the action is too much for multiple shots to capture without ghosting.
Body: Canon 7d - gripped | Canon Xsi - gripped |
Glass: 16-35 f 2.8L | 24-70 f2.8L | 70-200 f2.8L| 100 F2.8 L Macro| 50mm f/1.2L|for sale 50mm f 1.4
Flash: 580EX II (x2) | Battery Pack CP-E4
www.MaltesePhotography​.com (external link)
JFusion
Feb 14, 2010 11:24 |  #12
Neither here either. Mulitple RAW files...
Jeremi
http://www.jeremiblurt​on.com (external link)
JB Photography - Facebook Fan Page (external link)
5D Mark iii, 7D, 24-70 2.8L, 70-200 2.8L IS II, 100 Macro 2.8, Nifty, 100-400 4.5-5.6L and a bunch of other stuff.
Gary ­ McDuffie
Feb 14, 2010 12:13 |  #13
Doug pretty much said it all.
Gary
kirkt
Feb 14, 2010 16:53 |  #14
dugcross wrote in post #9607369 (external link)
Actually ... from HDRSoft's (Photomatix's) website:
Do I need to process bracketed RAW files to TIFF format first?
Yes, it is recommended to first process your bracketed RAW files in your favorite RAW converter, and then combine the converted TIFF or JPEG files in Photomatix. This is particularly recommended with Exposure Fusion, given that Exposure Fusion is intended for images that have been fully processed, either in-camera or through a RAW converter.
When generating an HDR image, having Photomatix directly process the RAW files is theoretically better for the accuracy of the 32-bit HDR image produced -- the data in RAW files represent the linear luminance values captured by the camera sensors, which is exactly what is needed for an HDR image. Also, the calculation of HDR values can rely on the exposure information retrieved from EXIF data when RAW files are used.
However, the RAW conversion of Photomatix Pro and Photomatix Light is not as good as the RAW conversion done in Photoshop, Lightroom, Aperture, DxO or other applications specialized in RAW conversion.
This is why you should process your bracketed RAW files in an application that is specialized in the RAW conversion task. Then, use the converted output as source images for Photomatix Pro or Photomatix Light.
If you have Lightroom and Photomatix Pro, it is easy to integrate both processes with the Lightroom Export Plug-In to Photomatix Pro.
When using a RAW converter with files intended for HDR merging, you should disable sharpening and uncheck all tonal and exposure-related automatic settings (especially the Exposure adjustment setting but also adjustments for contrast, shadow, etc.) which should be set to zero. This does not apply to files intended for Exposure Fusion, though. For Exposure Fusion, it is better to process your RAW files using the auto-settings of the RAW converter.
As a side note: Though shooting in RAW is definitely better than shooting in jpeg for the dynamic range, this is not really relevant anymore when several exposures are used -- if your bracketed shots properly cover the scene's dynamic range, jpegs will work as well as RAWs for creating an HDR image.
Link: http://www.hdrsoft.com …otomatix.html#p​rocess_raw (external link)
Also:
How did you take the Grand Canal picture on your example page while the boats were moving?
Taking differently exposed shots for HDR only works well with stills. For a scene with motion, the resulting image will show "ghosting" artifacts.
Most cameras have an automatic bracketing exposure function which lets them take three or more shots successively while automatically changing the exposure. This is still not fast enough in most cases of moving scenes, but in the case of the Grand Canal photo shown on our example page it was, as the boats' movements are almost unnoticeable in the final tone mapped image. There were two reasons for that:
1. The boats were moving slowly.
2. The three shots were taken with a camera offering a high burst rate (the 1D MKII which can take up to 8.5 frames per second).
Photomatix Pro includes an option that reduces ghosting artifacts for moving objects. When this option does not work well with your images, you can also try the ghost repair technique detailed in this tutorial (note that when the tutorial mentions HDR image, it refers to the tone mapped image in fact).
Link: http://www.hdrsoft.com …_photomatix.htm​l#ghosting (external link)
Kirk
Kirk
lankforddl
Feb 14, 2010 21:13 |  #15
I use photoshop CS4. When I used photomatix I could never get the same quality with real prints. They look good on a display though.
11,000 views & 0 likes for this thread, 18 members have posted to it.
1512 guests, 178 members online
