Striff,
Hope these comments help, While you do have some good color here these shots are lacking in peak action.
Wit that said it is a long season and things are just getting started so I hope to see more from you as the season progresses. There are others here that shoot more baseball than me and they may be able to add more.
Really good sports photos have faces, the ball.puck,ect in them and are cropped tight with straight horizons. Upload to about 700 on the long side when you post. Use standard crop ratios.
Shoot tight and crop tighter.
Your best shot here IMHO is #2 "IF" it was cropped correctly. It is still a very stock shot of which I have many myself but the timming is great.
1) To much going on here and has no clear subject.
2) I allready talked about above.
3) Butts,backs and elbows.
4) More B,Band Elbows. Cut off limbs.
5) No ball, no action.
6) Cropped a little tighter it may be useable.
7) B,B,Elbows.You need to be farther down the base line on this one.
8) I see what your going for here (with the dust) but .These can sometimes work if you have field access durring warm ups howerver they are warm ups and you will normally be lacking a batter and an ump and its totaly obvious its a warm up shot.
These comments are ment to help, not discourage. Thanks for posting these.
I look forward to seeing more.
