Thread started 15 Feb 2010 (Monday) 17:04
What lenses CANNOT be used on 5D
wesawit1st
Feb 15, 2010 17:04 |  #1
I took a photography class last year and I was thinking that my instructor told our class that there are certain kinds of lenses that have to be used on full frame cameras, such as the 5D... I could be wrong though when I think I heard this.
I currently have a 30D with a 50mm1.4 lens and a 28-135 and have been offered a 5D at a very reasonable price but I'm wondering if both of my lenses will work on the full frame.
I am also wanting to buy a wide angle lens and had rented a Tokina 12-24 for my 30D which I absolutely loved, but it seems that is one of the lenses that won't "work" with the 5D.
Am I wrong in thinking that some lenses won't work on the 5D?
Thanks in advance for any help.
Lori
MY GEAR 30D gripped / 50 mm f/1.4, IS 28-135, Sigma 10-20
Timphoto
Creme de la Curmudgeon
Gallery: 207 photos
Feb 15, 2010 17:07 |  #2
Both of your current lenses will work with a 5D.
EF-S lenses will not work with the 5D.
Tim
haknslash
Feb 15, 2010 17:08 |  #3
EF lenses for 5D. EF-S won't work.
7D | 50 f/1.4 | 85 f/1.8 | 135 f/2 L | 430EX II
wesawit1st
Feb 15, 2010 18:26 |  #4
So can someone tell me what wide angle lenses I could purchase that are more on the inexpensive side. As I mentioned before, I was wanting a 12-24 Tokina but this would be much wider on the 5D. Would the Tokina even work on the 5D? Another one I was considering with my 30D was the Sigma 10-20.
Sorry for so many ?'s.
Lori
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Feb 15, 2010 18:30 |  #5
Sigma 12-24
Canon 17-40
Canon 16-35
Canon 24-105
Canon 24-70
Canon 28-70
Sigma 24-70
Sigma 24-60
These will work without vignetting. Other wide angle/ultra wide angles may mount to the 5D but will vignette.
mastertech01
Feb 15, 2010 20:09 |  #6
Canon 17-35mm 2.8L and 20-35mm 2.8L are older but useful and often can be found at lower prices.
FuturamaJSP
Feb 15, 2010 20:11 |  #7
I believe all Sigma DC lenses won't work on full frame cameras. Well they would mount but you would only get an image circle :S
They asked me how well I understood theoretical physics. I said I had a theoretical degree in physics. They said welcome aboard! - Fallout New Vegas
blah blah blah
DA (external link)
stargazer78
Feb 15, 2010 20:18 |  #8
wesawit1st wrote in post #9616109 (external link)
Don't forget that your EF 28-135mm lens will become much wider on a 5D than it was on the 30D. For full frame, that lens is already classified as a wide angle zoom. Anything wider would be considered an ultra-wide angle zoom lens.
To be honest, the lenses you have are just perfect for transition to full frame. They are far better suited for the 5D than they were on a 30D. If you have a good deal on a 5D, by all means jump on it.
mtran
Feb 15, 2010 20:40 |  #9
The tokina will work, but you'll have a small range of use. Better off buying the 17-40L used for cheap!
GEAR Canon 7D | Canon 40D | Canon 430EX II | Canon 10-22 f3.5-4.5 | Sigma 18-50mm f2.8 EX DC Macro | Canon 50mm f1.8 II | Lowepro Flipside 400AW | Crumpler 6MDH | Slik Sprint Pro II GM Tripod
spacetime
Feb 16, 2010 12:35 |  #10
FuturamaJSP wrote in post #9616761 (external link)
Correct, DC lenses will mount but leave heavy vignetting. I don't believe they will contact the mirror assembly like an EF-S lens will and cause damage. The Sigma DG model line will fit FF bodies without issue.
I'm not sure how Tamron or Tokina label their lenses to distinguish if a lens is FF compatible.
Hobbes330i
Joined Jun 2005
Feb 16, 2010 12:47 |  #11
+1 Canon 17-40L on FF
7D | 5D
1
7-40L, 24-105L, 70-300 DO, Sigma 30 and 50, Tamron 28-75 f/2.8, Tamron 17-50 f/2.8 alphabet soup
egordon99
Feb 16, 2010 12:48 |  #12
emitecaps wrote in post #9620757 (external link)
Tamron uses Dii for crop lenses, and Tokina uses DX.
spacetime
Feb 16, 2010 13:30 |  #13
egordon99 wrote in post #9620850 (external link)
Okay so:
Canon:
EF=FF compatible
EF-S= crop only (contacts mirror assembly and will cause physical damage)
Sigma
DG=full frame
DC=crop (causes heavy vignetting)
Tamron
Di= FF compatible
Di II= crop
Tokina
DX=crop
Will the Di II or DX contact the mirror and cause damage or do they just have vignetting due to reduce image circle?
egordon99
Feb 16, 2010 13:33 |  #14
emitecaps wrote in post #9621108 (external link)
Okay so:
Canon:
EF=FF compatible
Sigma
DG=full frame
Tamron
Di= FF compatible
Di II= crop
Tokina
DX=crop
I'm pretty sure those will physcially mount fine, but will have severe vignetting. Canon is the only manufacturer that uses a physically different mount for the crop vs. full-frame formats.
professoryeti
Feb 16, 2010 13:52 |  #15
I got my Tamron 17-35 f/2.8-4 for a little bit of nothing. I don't feel like it's a permanent solution, but it's sharp enough and wide enough (good lord is 17 wide on FF!) to take my mind off the wide end so I can worry about some other things.
Saturnalia for all you have.
5D Mark II | 5D | 24mm f/1.4L II | 35mm f/1.4L | Nikkor 50mm f/1.2 | Canon 100mm f/2.8L | 24-105mm f/4L | 70-200mm f/2.8L IS II |
JoshNibertPhotography.​com (external link)
Facebook (external link)
2,758 views & 0 likes for this thread, 14 members have posted to it.
1645 guests, 174 members online
