Thread started 16 Feb 2010 (Tuesday) 18:23
Continuous shooting w/ 50 1.8
Diver-Down
Feb 16, 2010 18:23 |  #1
Was taking some pictures at my nephews basketball game tonight and noticed that my 50 1.8 will not shoot high speed continuous shots with my 50D. I was in M mode and shutters were around 1/500. It was shooting at probably 3-4 fps. I put on the 70-200 and it shot full speed. Came home and tried them both again in the house and the 50 1.8 was slow again.
Any ideas how this could be ?
Heath
Joined Sep 2009
Feb 16, 2010 18:24 |  #2
Manual or Auto Focus?
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
JHutter
Feb 16, 2010 18:34 |  #3
Diver-Down wrote in post #9622975 (external link)
High ISO noise reduction enabled? That will slow it down, but this doesn't really fit since the 50/1.8 is a faster lens, so should not have needed a faster ISO even on auto ISO.
70D | 15-85 IS | 28/1.8 | 40/2.8 | 50/1.8 | 60/2.8 | 100/2 | 70-200/4 IS | 200/2.8 | 430EX II
Tim ­ Kostka
Feb 16, 2010 18:47 as a reply to  @ JHutter's post |  #4
Do you shoot in focus priority or release priority? Sounds like it's the former. It's one of the custom functions.
Focus priority + slow AF = slower shots.
That's my guess, at least.
Zenfolio (external link) | Picasa Web (external link)
Canon EOS 7D | EF 24-105mm L | EF-S 10-22mm | EF-S 18-135mm | Sigma 50-500mm | 580EX II | Feisol CT-3441SB Tripod
Diver-Down
Feb 16, 2010 19:05 as a reply to  @ Tim Kostka's post |  #5
AF with both lenses
focus priority or release priority? Don't know where that is in my 50D ??
Was also shooting in AI Servo
Just tried one shot with the 50mm and what do ya know..it shoots high speed. Went back to AI Servo and low speed, even though I kept the camera still and didn't track anything.
I've read an awful lot about the nifty fifty and never heard of this. Anyone else ??
DreDaze
Gallery: 49 photos
Feb 16, 2010 19:43 |  #6
Diver-Down wrote in post #9623264 (external link)
AF with both lenses
no clue as to why...but i can tell you from just testing my 40D and 50mm f1.8...it does the same as your 50D, and fifty...
one shot continuous is much faster than AI SERVO
not sure if there's a way to fix it or not by changing some settings
Andre or Dre
gear list
Instagram (external link)
themadman
Feb 16, 2010 19:48 |  #7
Nifty fifty has bad and slow autofocus. If the camera doesn't think the shot is focused, it won't shoot. I think certain bodies have a custom function to change that.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
DreDaze
Gallery: 49 photos
Feb 16, 2010 19:53 |  #8
themadman wrote in post #9623475 (external link)
but in AI servo that doesn't really matter...the shot doesn't have to be in focus to take a shot...
at first i thought the o.p. would for sure be in one shot, and that focus just wasn't achieved yet...but once it focuses, and you hold down the shutter button...it keeps going...
Andre or Dre
gear list
Diver-Down
Feb 16, 2010 19:59 as a reply to  @ DreDaze's post |  #9
I'm thinking that it's in the design. They realize that the lens is soo slow focusing that it would never be able to keep up with high speed shooting, so why waste the shots.
bobbyz
Feb 16, 2010 20:39 |  #10
DreDaze wrote in post #9623506 (external link)
Actually it does.
One 1 series you can select focus priority or drive priority. You only going to get max fps when using manual AF, one shot mode atleast on xxD series.
Fuji XT-1, 18-55mm
DreDaze
Gallery: 49 photos
Feb 16, 2010 20:51 |  #11
bobbyz wrote in post #9623733 (external link)
Actually it does.
does it?...when i switch to ai servo i can fire off a shot before the red light blinks...
Andre or Dre
gear list
BenJohnson
Feb 16, 2010 20:58 |  #12
The red light never blinks in AI Servo....
|Ben Johnson Photography (external link)|
|Gear List|
msowsun
"approx 8mm"
Gallery: 18 photos
Feb 16, 2010 21:17 |  #13
I asked Chuck Westfall about this problem. Here is his answer.......
http://digitaljournali​st.org …tips.html#comme​nt-2234509 (external link)
THE DIGITAL JOURNALIST
Tech Tips
June 2008
by Chuck Westfall
I have recently noticed that my older EF Arc-Form Drive lenses will cause the frame rate to drop to about 4fps on my 40D when shooting in "AI SERVO". Even with a stationary subject and the camera on a tripod.
This doesn't happen in "ONE SHOT". In "AI FOCUS" I will get 6.5fps, but as soon as the subject moves, it again slows to 4ps or less.
Can you please explain why this is so?
Mike Sowsun
Except for the EF80-200mm f/2.8L and EF20-35mm f/2.8L, all other EF lenses with AFD (Arc Form Drive) focusing motors were designed in such a way that autofocusing and diaphragm operation (via the Electromagnetic Diaphragm, or EMD for short) were carried out sequentially rather than simultaneously. This has no impact on continuous sequences in One-Shot AF, because no autofocusing occurs after the initial AF lock in this mode. But in AI Servo, both the focus and the diaphragm are operated for each photo, and consequently the camera's framing rate decreases.
For what it's worth, AFD motors were phased out of the EOS system for all new lenses introduced from 1990 onwards.
Best Regards--Chuck Westfall
DreDaze
Gallery: 49 photos
Feb 16, 2010 21:20 |  #14
BenJohnson wrote in post #9623841 (external link)
yeah i guess it just blinks in the beginning...but i can take shots with the 50mm while it's focusing that are totally out of focus...the shots are taken while the lens is hunting back and forth...
Andre or Dre
gear list
nureality
Feb 16, 2010 21:22 |  #15
That is incorrect Dre. AI SERVO (at least in the iterations before the 7D, i.e. 20D, 30D, 40D, and perhaps 50D (dunno never had one)) will keep shooting at full speed as long as its getting (what it thinks is) focus lock for every shot. With the 7D (and perhaps 50D) there are two C.Fn's that handle how AI Servo AF behaves.
C. Fn III-2 "AI Servo 1st/2nd image priority"
0: AF priority/Tracking priority
1: AF priority/Drive speed priority
2: Release/Drive speed priority
3: Release/Tracking priority
of the 4 choices, Choice 2 is the fastest because even with the first shot of the sequence the AF system does not wait for AF Lock, its priority is shutter release.
of the 4 choices, I use 0 for the simple reason that the 70-200 f/4L IS USM which is the main reason for such speed for me can actually keep up. 2nd fastest lens is probably my 100mm f/2.8 Macro USM, followed by the 17-55 f/2.8 IS USM. The speed of the lens's AF motor plays a major role in how the AI SERVO will work. If the lens is slow and your priority is choice 0 for example, you won't likely be able to maintain full 8fps on the 7D. I know on my 40D and 30D before it, slow lenses like the 75-300 III would no go faster than 3fps in AI SERVO, even in High Speed Continuous motor drive. Simply put AI SERVO was originally designed to keep shooting as long as AF is found - no lock, no shot.
What I used to do with my 40D before I got the 70-200L was I'd set my AF to ONE SHOT and High Speed. It ended up doing the same as option C.Fn III-3 Option 1. It locks for the first shot, then just shoots more of the same focus. AI SERVO on the 7D is a lot better tho because now it can still give a damn about focusing the subsequent shots - something ONE SHOT AF is not meant to do.
C.Fn III-3 "AI Servo AF tracking method"
0: Main focus point priority
1: Continuous AF track priority
This function deals more with tracking priorities... i.e. if something gets between you and the subject over the course of a sequence... like a tree that gets between you and your dog.
Alan "NuReality" Fronshtein
Gear List | PBase |  (external link)flickr (external link)
Lots of Fun, Lots of Laughs, Happy Trigger Finger!
3,028 views & 0 likes for this thread, 10 members have posted to it and it is followed by 2 members.
1332 guests, 137 members online
