Quick question,
Would a canon or generic canon hood work on a Tokina lens of the same size? For example, the hood for the 10-22 being used on the 12-24 Tokina? (both being 77mm?)
Just curious, thanks!
Invertalon Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | Feb 16, 2010 18:31 | #1 |
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Feb 16, 2010 18:45 | #2 Bayonet design is different, cannot mount it. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Invertalon THREAD STARTER Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | Feb 16, 2010 18:53 | #3 |
Feb 16, 2010 19:51 | #4 Even without mounting issues, many hoods are designed to block as much light as possible while also avoiding vignetting, and that varies from lens to lens. If you could mount it, it might work, it might vignette anyway. Website: Iowa Landscape Photography
RickAnderson Senior Member 565 posts Likes: 16 Joined Apr 2007 More info | The 12-24 Tokina is such a short lens that nearly any hood will cause vignetting. The original Tokina hood is a flower type that is only about an inch long and it's diameter is about 95mm at the point where it is actually covering the lens. Although I like them on long zoom lenses, a screw-on rubber filter would vignette terribly with the 12-24 lens.
Invertalon THREAD STARTER Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | Feb 17, 2010 13:54 | #6 |
Feb 17, 2010 15:11 | #7 Rick Anderson wrote in post #9628007 The 12-24 Tokina is such a short lens that nearly any hood will cause vignetting. The original Tokina hood is a flower type that is only about an inch long and it's diameter is about 95mm at the point where it is actually covering the lens. Although I like them on long zoom lenses, a screw-on rubber filter would vignette terribly with the 12-24 lens. Would it still vignette on a crop body? I don't have anything as short as 12mm, but I do have the 17-40mm, and the screw-on rubber hood works fine, though I do have to be careful when at 17mm when I have the hood AND a polarizer filter on there. I know I could never do that on a FF body. Website: Iowa Landscape Photography
| Latest registered member was a spammer, and banned as such! 2845 guests, 166 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
