I'm looking to pick up one or the either.
Right now I'm using my Camulet ones I picked up somewhile back.
But I'm thinking about buying one or the other brand.
Any recommendations ?
Issues ?
Pros?
Cons?
Eiro Goldmember 1,368 posts Likes: 27 Joined Dec 2009 Location: U.S. More info | Feb 18, 2010 10:42 | #1 I'm looking to pick up one or the either. Get out and shoot
AlanU Cream of the Crop More info | Feb 18, 2010 11:31 | #2 Eiro wrote in post #9633447 I'm looking to pick up one or the either. Right now I'm using my Camulet ones I picked up somewhile back. But I'm thinking about buying one or the other brand. Any recommendations ? Issues ? Pros? Cons? Thanks cybers are inexpensive and never misfire. That sums it up. 5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
gonzogolf dumb remark memorialized More info | Feb 18, 2010 11:35 | #3 AlanU wrote in post #9633746 cybers are inexpensive and never misfire. That sums it up. ^^^^^^
robojack Senior Member 520 posts Likes: 1 Joined Sep 2007 More info | Feb 18, 2010 12:04 | #4 Newer PWs (FlexTT5 and miniTT1) have the Hypersync feature, allowing you to fire past the 1/250th sync speed without having to resort to using HSS, up to 1/500 easily. This is also stopping me from getting Cybersyncs and never regret passing on the PW's. 5DMk2 | 5D Classic /w BG-E4 | EF 35 f1.4L (main) | Sigma 85 f/1.4 (main) | 430EX | LP160| LP120 | AB800 | Armatar 100
BigMike Goldmember 1,023 posts Joined May 2006 Location: Edmonton More info | Feb 18, 2010 12:09 | #5 Newer PWs (FlexTT5 and miniTT1) have the Hypersync feature, allowing you to fire past the 1/250th sync speed without having to resort to using HSS, up to 1/500 easily. This is also stopping me from getting Cybersyncs and never regret passing on the PW's. The newer PW can also give you E-TTL metering (with Canon units). Instructor at The Canadian Photography Learning Centre
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Feb 18, 2010 14:41 | #6 I have CS and no problems. Except now when I am shooting with others I need to use PW Plus II. So I am going from CS to PW PLus II. Fuji XT-1, 18-55mm
alpinekiwi Member 39 posts Joined Feb 2010 Location: Morzine, France More info | Feb 18, 2010 14:50 | #7 I'm happy enough with my CS.
gonzogolf dumb remark memorialized More info | Feb 18, 2010 14:52 | #8 alpinekiwi wrote in post #9635005 I'm happy enough with my CS. Only issue with them is they can't see round corners very well. They are a 'line of sight' trigger to some extent. Anything like concrete/steel will interfere with the reception. Not a big deal really, but something you need to be aware of. They will go through walls fine so I have to disagree with your description. I understand your point about steel and concrete messing with reception but calling them line of sight is a leap.
kobe629 Senior Member 694 posts Joined Feb 2007 Location: Los Angeles More info | Feb 18, 2010 14:53 | #9 The one thing I like about the PW II is that they both transmit and receive so if one PWII goes bad you you can just buy the same one. And you don't have to buy two separate for receiver and transmitter. Nikon
snyderman Cream of the Crop 7,084 posts Likes: 8 Joined Nov 2008 Location: Wadsworth, Ohio More info | Feb 18, 2010 15:42 | #10 Another vote for the Cybersync products. On recommendations here at POTN, I went with them. They work as advertised and perform flawlessly. Very satisfied customer here. Canon 5D2 > 35L-85L-135L
Feb 18, 2010 21:53 | #11 kobe629 wrote in post #9635022 The one thing I like about the PW II is that they both transmit and receive so if one PWII goes bad you you can just buy the same one. And you don't have to buy two separate for receiver and transmitter. I like that part too. Thats what Im thinking about. buttt mannn they cost a nice little dollar Get out and shoot
gonzogolf dumb remark memorialized More info | Feb 18, 2010 21:55 | #12 Eiro wrote in post #9637432 I like that part too. Thats what Im thinking about. buttt mannn they cost a nice little dollar Enough that you could keep an extra cybersync trigger and receiver on hand for redundancy.
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Feb 18, 2010 22:28 | #13 Only issue with them is they can't see round corners very well. They are a 'line of sight' trigger to some extent. Anything like concrete/steel will interfere with the reception. Really?
AlanU Cream of the Crop More info | Feb 18, 2010 22:32 | #14 I have both 3x flexTT5's and cybersyncs. 5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
JayCeeImages Goldmember 1,544 posts Joined Aug 2007 Location: CA More info | Feb 18, 2010 22:45 | #15 alpinekiwi wrote in post #9635005 I'm happy enough with my CS. Only issue with them is they can't see round corners very well. They are a 'line of sight' trigger to some extent. Anything like concrete/steel will interfere with the reception. Not a big deal really, but something you need to be aware of. Well then yours are broken... Nobody cares about your gear list...
| Latest registered member is semonsters 1523 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
