Thread started 18 Feb 2010 (Thursday) 22:44
Specific clamp
javig999
Feb 18, 2010 22:44 |  #1
I purchased a set of 6.5' stands and 32" umbrellas from a local CL seller and the kit comes with a bracket that holds the umbrella and what appears to be some sort of modeling lamp that is built in - no coldshoe mount. I know that I can use a coldshoe shoe-umbrella bracket on the light stand, but is there a specialized bracket or clamp that I can use to attach the flashgun (285HV with Cactus trigger) on to the shaft of the light stand, or even the umbrella shaft so that I can use the modeling lamps if/when I want to? The latter may be dangerous from a weight standpoint I realize, but in messing with it tonight (using velco straps that let it slide down the umbrella shaft!), it did not appear to make the setup top heavy. I do not think I would use the modeling lamps often, but it would be nice to have the option.
Thanks in advance...
7D | 8mm 3.5 FE | EF-S 10-22 | EF-S 17-55 2.8 IS | EX DC 30 1.4
EOS R | Samyang 14 2.8 | Sigma 15mm f2.8 DFE | RF 16mm | Art 20/35/50/85 f1.4 | EF 100 f2.8 Macro | EF 135 f2L | EF 70-200 f2.8L IS | Sigma C 150-600
1stGenRex
Feb 19, 2010 17:21 |  #2
sounds like this might be of help to you?
http://www.google.com …l=en&ie=UTF-8&sa=N&tab=iw (external link)
781 views & 0 likes for this thread, 2 members have posted to it.
Specific clamp
977 guests, 108 members online
