Thread started 19 Feb 2010 (Friday) 04:00
Octagonal Softbox 47 .2" with Dlite 4
Waldo ­ Pepper
Feb 19, 2010 04:00 |  #1
Is Dlite 4 bears the weight of an octogonal 47.2" softbox?
1DMKIII ,5DMKII
sdipirro
Feb 19, 2010 12:42 |  #2
I used to regularly use a 60" Photoflex octa on one of my Dlite-4's, and it worked...but had to be watched closely. It felt borderline on the old Dlite-4 mount. I'm not sure if the new Dlite-4's are improved in that area.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
Waldo ­ Pepper
Feb 19, 2010 13:01 |  #3
sdipirro wrote in post #9640664 (external link)
Thanks for your answer. ;)
1DMKIII ,5DMKII
TMR ­ Design
Joined Feb 2006
Feb 19, 2010 13:12 as a reply to  @ Waldo Pepper's post |  #4
I don't think you'll have a problem with a 48" modifier. Some people have very successfully used 60" Octa's and others have reported that the mount and housing are just not strong enough.
Assuming that the accessory mount is strong enough you can eliminate the swivel mount for the light stand by using the Photoflex (or equivalent) speed ring (external link) and mount the speed ring to the light stand via the threaded 1/4"-20 or 3/8"-16 on the speed ring. Mounting it this way removes all the weight and stress that was on the swivel mount and now it's moved to the speed ring. For an octa where you don't need to rotate the modifier it's a great solution, but keep in mind that this only works IF the accessory mount on the strobe can safely support the modifier in the first place.
Robert
Waldo ­ Pepper
Feb 19, 2010 13:49 |  #5
TMR Design wrote in post #9640864 (external link)
It's important,Thank you ;)
1DMKIII ,5DMKII
hawk911
Feb 19, 2010 14:51 |  #6
I use my 53" octo on my D4 without any problems. I've bolstered up the pivot arm screws though.
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
Semmonka
Feb 20, 2010 00:27 as a reply to  @ hawk911's post |  #7
I´ve had no problems with 53" octa and D2
Vesa
"Opinions are like a$$holes, everybody has one"
Flick (external link)r (external link) | MM (external link)
Waldo ­ Pepper
Feb 20, 2010 06:16 |  #8
Thanks for your help,guys !
Go for a 47" Octa !!!!!
1DMKIII ,5DMKII
1,454 views & 0 likes for this thread, 5 members have posted to it.
1736 guests, 170 members online
