I will be doing my first set of portraits soon and I was wondering if I should go ahead and start watermarking, and if so, what can I use to do it?!
jpbimages Senior Member 474 posts Joined Feb 2010 Location: Greenville, Sc More info | Feb 20, 2010 01:38 | #1 I will be doing my first set of portraits soon and I was wondering if I should go ahead and start watermarking, and if so, what can I use to do it?!
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | Feb 20, 2010 01:43 | #2 It is a personal prefence. If you are putting them online for persons to view and then order from, I would recommend that you watermark them. I put a low opacity watermark across the middle of the image as well as my identity and the © in the lower right corner. My life is like one big RAW file....way too much post processing needed.
silvex Cream of the Crop More info | Feb 20, 2010 04:08 | #3 |
| Latest registered member is MWCarlsson 1265 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
