I took some pictures here (https://photography-on-the.net/forum/showthread.php?t=823208) and received comments on a general theme about the light fall off and blending into the background. Here is my second take. Am I getting closer?
1
2
3
4
imahawki Goldmember 1,455 posts Likes: 1 Joined Aug 2008 Location: Omaha, NE More info | Feb 20, 2010 08:14 | #1 I took some pictures here (https://photography-on-the.net/forum/showthread.php?t=823208) and received comments on a general theme about the light fall off and blending into the background. Here is my second take. Am I getting closer? 2 3 4 Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
IVOlution Goldmember 2,039 posts Likes: 35 Joined Jan 2010 Location: bArcelona, sPain More info | Feb 20, 2010 11:46 | #3 yES U R my.com
SamAlfano Senior Member 719 posts Likes: 1 Joined Jul 2005 Location: Covington, Louisiana More info | Feb 20, 2010 15:24 | #4 Looking at the nose shadow and catchlights in the top photo, the light appears too low. The shadow should extend downward and to camera right. Catchlights should be at the 10 o'clock position. The camera-right side of her head is a bit dark and blends in with the background. With a bit of tweaking of the lights you can really nail this portrait. Gently lighting the background and her hair and shoulder would be good, too.
Feb 20, 2010 16:18 | #5 Yeah, I need to get either another light OR a reflector. Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
SamAlfano Senior Member 719 posts Likes: 1 Joined Jul 2005 Location: Covington, Louisiana More info | Feb 20, 2010 23:04 | #6 Here's a good resource for you. Zeltsman Guide to Classic Portraiture.
Slaterza Goldmember 2,007 posts Likes: 7 Joined Nov 2007 Location: Beijing, China More info | Feb 21, 2010 09:39 | #7 You are getting closer just a few tweaks and you will get there. You need more light on her hair especially in the first one. A reflector would be an easy solution just a piece of white foam core or a piece of mylar both inexpensive solutions found at most art supply stores. Keep working and keep showing the results. Sam Laterza flickr
rushhour Member 88 posts Joined Jan 2010 Location: Mississauga, Ontario, Canada More info | Feb 21, 2010 10:43 | #8 abigailandsam wrote in post #9649684 Here's a good resource for you. Zeltsman Guide to Classic Portraiture. http://jzportraits.home.att.net/ There's much to be learned there, especially the art of posing. Thanks for this link, certainly one to add for the bookmarks. My Gear: Canon 5D Mark II • Canon Rebel XSi • Canon 85mm 1.8 • Canon 50mm 1.8 • Tamron 17-35
| Latest registered member is RawBytes 1399 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
