Thread started 20 Feb 2010 (Saturday) 19:34
Ballhead Tripod Question?
cristphoto
Feb 20, 2010 19:34 |  #1
I just got a new Manfrotto ballhead tripod (head #496RD2). It has a small knob (friction) and a large knob (lock). This may sound simple (this is my first ballhead) but which is the best way to adjust the head - which knob when? Thanks.
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
bohdank
Feb 20, 2010 19:46 |  #2
Loosen both completely. Mount camera/lens that you are planning on using and start tightening the friction knob, until the camera/lens, with hands off, does not drop. Try different positions, pointing straight away, slightly down, etc. Once you get this equilibrium, make sure that you can still adjust the camera/lens on the head by just grabbing the camera/lens and moving it. If too tight, back off the friction control just a tiny touch. Once adjusted, leave the friction control alone and use the main knob to loosen/tighten downt he head.
The friction control is to prevent the camera from dropping if you happen to take you hand off the camera with the main knob loose. With short lenses this is not an issue but you wouldn't want a long lens to swing down and whack the tripod.
cristphoto
Feb 20, 2010 20:15 |  #3
Thanks for the quick reply. I've always used the heads with three handles that are self-explanatory. I got this because it was lighter and more compact for when I go outside.
1,240 views & 0 likes for this thread, 2 members have posted to it.
1154 guests, 136 members online
