Thread started 21 Feb 2010 (Sunday) 12:28
Understanding ETTL
extrememc
Feb 21, 2010 12:28 |  #1
I just purchase a low budget flash with ETTL (Opteka EF 600) and was wanting some links on reading material. I somewhat understand what it does. The thing that I am not understand is when u take it off camera using cord or wireless. The strobe is at a fixed distance from the subjest. While the camera is traveling around the subject. How does the strobe know how much light the subject needs?
Photography is an expression of the mind!!!!!!!!!!!!!
30D T3i 7D 1D MkIII Canon Eos M
rjc1
Feb 21, 2010 12:39 |  #2
I could be wrong but if the flash is stationary it doesn't matter where the camera is. The light output from the flash reaching the subject is the same no matter where the camera is.
40D with 28-135 IS , Tamron 17-50 ,100-400 f4.5-5.6L, 100mm f2.8L macro IS, 430EX, 430EXll,MiniTT1/FlexTT​5 , Kata R-103,
Domke F2 shooters bag
lancemoreland
Joined Nov 2005
Feb 21, 2010 12:45 as a reply to  @ rjc1's post |  #3
This should get you started. Written by Chuck Gardner.
http://super.nova.org/​DPR/Canon/ (external link)
Lance
www.lancemoreland.com (external link)
Wilt
Feb 21, 2010 13:42 |  #4
In ETTL, the camera sends a signal to the flash (on- or off-camera, if it is connected via off-camera cord or via a wireless that supports ETTL signaling). The flash emits the pre-flash, the camera meters the emitted light reflected back from the subject, and then the camera tells the flash how much light to send out for the main exposure. As RJC1 said, the camera distance does not matter, it is the flash-to-subject distance which is subject to Inverse Square Law of falloff of light intensity.
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Feb 21, 2010 13:46 |  #5
E-TTL II requires that you have a flash mounted on-camera, or on a compliant off-camera E-TTL cord. The camera asks the flash to emit a low-power pre-flash so that the camera can determine the difference between an ambient exposure reading and the flashed exposure reading. The required settings are then given to the flash, and it is told to fire. It is the camera which determines the exposure required, in accordance with your settings on both camera and flash.
For Canon Wireless, a second E-TTL-compliant flash is required as Master, or a 7D camera body, or the latest Pocket Wizards. RadioPoppers require two flashes to provide the coding stream.
Simple radio triggers cannot handle the complex E-TTL communications between camera and flash.
Pixel have the promise of E-TTL at a mid-price, and do not require a Master flash, but they are overdue for releasing the TR-332. Read first assessments when they are published, before buying.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
extrememc
Feb 22, 2010 09:19 |  #6
When using a ettl flash with a modifier do you have to compensate for the light you will lose? If so how?
Savas ­ K
Feb 22, 2010 09:32 |  #7
Flash exposure compensation.
Here is a nice Canon article on flash:
http://www.usa.canon.c​om …ArticleAct&arti​cleID=2930 (external link)
Titus213
Feb 22, 2010 10:01 |  #8
extrememc wrote in post #9657644 (external link)
In ETTL mode the theoretical answer is no - YMMV. The pre-flash measured by the camera is traveling the same route as the main flash will travel so it should already be compensated for.
That said, the use of FEC is always quick and easy.
Dave
Perspiring photographer.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 22, 2010 14:42 as a reply to  @ Titus213's post |  #9
I agree with Dave. E-TTL will take care of that automatically. But flash exposure compensation may still be needed, as you may come to a different conclusion than the E-TTL logic does.
Like in this picture (external link), where I had to use a FEC of 1 2/3 steps, due to the white snow fooling the E-TTL metering into severe underexposure. Fortunately, I've been around long enough to understand that before I took the picture, so I took some test shots before the action started, to understand how much to change the flash power. Once that action started, it didn't last long...
Anders
themadman
Feb 22, 2010 14:47 |  #10
Watch this and become enlightened
http://cpn.canon-europe.com …asterclass/cano​n_flash.do (external link)
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Savas ­ K
Feb 22, 2010 16:28 |  #11
E-TTL does not know that you have a modifier installed on the flash head, ergo, flash exposure compensation.
Titus213
Feb 22, 2010 19:32 |  #12
Savas K wrote in post #9660442 (external link)
ETTL doesn't care that you have a modifier installed, ergo, no adjustment needed.
Dave
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Feb 22, 2010 19:37 |  #13
ettl measures the preflash at the sensor, so the effect of any modifier is accounted for at the sensor. Thats what ettl means, through the lens...
ootsk
Joined Jan 2002
Feb 22, 2010 20:02 |  #14
Titus213 wrote in post #9661460 (external link)
Bingo.
Any light loss by a modifier is basically the same as the flash being further away. It automatically adjusts the power of the flash to compensate.
CliveyBoy
Joined Nov 2005
Feb 23, 2010 01:15 |  #15
ootsk wrote in post #9661659 (external link)
Bingo.
Within the limits of the maximum available flash output.
7,448 views & 0 likes for this thread, 18 members have posted to it.
Understanding ETTL
1834 guests, 137 members online
