Just curious what everyone uses, because I'm a noob to pp and photography in general.
Thanks.
jonahrei Senior Member 284 posts Joined Dec 2009 Location: Oakland, CA More info | Feb 21, 2010 21:14 | #1 Just curious what everyone uses, because I'm a noob to pp and photography in general. 5D MK II | 7D | 70-200L F4 IS | 24-70L F2.8 | 17-40L F4 | Σ 85 F1.4 | Σ 50 F1.4 | Σ 15 F2.8 Fisheye | 2 Alien Bees 1600 | Alien Bee 400 | 580 EXII | Cybersyncs
CanonGolfer Senior Member 515 posts Joined Nov 2009 Location: Tucson More info | Feb 21, 2010 21:51 | #2 Depends on what you want to sharpen and how much. I usually use either a High Pass filter or Smart Sharpen. Just toy around with them for a while and see what works best for you. http://www.stevenmichaelphotography.com/
are those stand-alone softwares for sharpening? I have aperture and cs4. I've been toying around w/ aperture, but I really can't see much of a difference when I sharpen. CS4 I haven't even tried to use USM. I'm not really to good w/ photoshop. 5D MK II | 7D | 70-200L F4 IS | 24-70L F2.8 | 17-40L F4 | Σ 85 F1.4 | Σ 50 F1.4 | Σ 15 F2.8 Fisheye | 2 Alien Bees 1600 | Alien Bee 400 | 580 EXII | Cybersyncs
That_Fox "In the Witless Protection Program" 1,386 posts Joined Jun 2008 Location: Southern California More info | Feb 21, 2010 22:04 | #4 |
EOS_JD Goldmember 2,925 posts Likes: 2 Joined Dec 2005 Location: Lanarkshire, Scotland More info | Feb 21, 2010 22:08 | #5 Copy the red channel. Ctrtl click the red channel and then select RGB. Now unsharpen mask and select an amount of 300. Ctrl H gets rid of the marching ants and keeps the selection live. All My Gear
Feb 21, 2010 22:37 | #6 That_Fox wrote in post #9655330 What I usually do is duplicate the original layer and set the mode to soft light. Then I do a high pass filter on the duplicate layer, adjusting the settings as needed for the photo. EOS_JD wrote in post #9655344 Copy the red channel. Ctrtl click the red channel and then select RGB. Now unsharpen mask and select an amount of 300. Ctrl H gets rid of the marching ants and keeps the selection live. Try it on a portrait! Guy Gowan uses this method. So both of you use photoshop? 5D MK II | 7D | 70-200L F4 IS | 24-70L F2.8 | 17-40L F4 | Σ 85 F1.4 | Σ 50 F1.4 | Σ 15 F2.8 Fisheye | 2 Alien Bees 1600 | Alien Bee 400 | 580 EXII | Cybersyncs
That_Fox "In the Witless Protection Program" 1,386 posts Joined Jun 2008 Location: Southern California More info | Feb 21, 2010 22:38 | #7 jonahrei wrote in post #9655510 So both of you use photoshop? Yes, I use Photoshop CS3. Apparently I've been dubbed Foxy.
S2K.OGRAPHY Senior Member 494 posts Joined Mar 2009 Location: Miami More info | Feb 21, 2010 22:41 | #8 i follow this...i found it in a thread on here IMG NOTICE: [NOT AN IMAGE URL, NOT RENDERED INLINE]
Lyndön Goldmember More info | Feb 21, 2010 22:48 | #9 I also use CS3, and I've found that using the high pass filter with soft light *mostly* or one of the other light options on a duplicate layer works well for me. I like how I can vary the opacity of the sharpened later and paint out what I don't want with a mask. You can't do that when you just apply USM to your entire image.
That_Fox "In the Witless Protection Program" 1,386 posts Joined Jun 2008 Location: Southern California More info | Feb 21, 2010 22:52 | #10 Josh_30 wrote in post #9655571 I also use CS3, and I've found that using the high pass filter with soft light *mostly* or one of the other light options on a duplicate later works well for me. I like how I can vary the opacity of the sharpened later and paint out what I don't want with a mask. You can't do that when you just apply USM to your entire image. Just don't go too crazy with the high pass filter. Turn it up just enough to increase the detail of your shot, but not so much that you're sharpening the noise as well. I generally run noise ninja on high ISO photos before using the high pass technique, and it seems to help. That about mirrors my workflow. I always run noise ninja before I duplicate the layer and run the high pass filter. And good point about about the other light options, I use soft light most often, although I do use the other modes as well. Apparently I've been dubbed Foxy.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Feb 22, 2010 05:13 | #11 I used to do a lot of high pass sharpening but since I started using Lightroom 2 whose output sharpening incorporates the main features of the Pixelgenius plugin, I usually let LR do the sharpening, although for critical large prints I may still pull a tif just to check its sharpening. Elie / אלי
S2K.OGRAPHY wrote in post #9655523 i follow this...i found it in a thread on here IMG NOTICE: [NOT AN IMAGE URL, NOT RENDERED INLINE] Thanks for sharing that guide! Josh_30 wrote in post #9655571 I also use CS3, and I've found that using the high pass filter with soft light *mostly* or one of the other light options on a duplicate layer works well for me. I like how I can vary the opacity of the sharpened later and paint out what I don't want with a mask. You can't do that when you just apply USM to your entire image. Just don't go too crazy with the high pass filter. Turn it up just enough to increase the detail of your shot, but not so much that you're sharpening the noise as well. I generally run noise ninja on high ISO photos before using the high pass technique, and it seems to help. Thanks! I'm going to try the high pass filter asap. I have a couple pics that I need to sharpen. 5D MK II | 7D | 70-200L F4 IS | 24-70L F2.8 | 17-40L F4 | Σ 85 F1.4 | Σ 50 F1.4 | Σ 15 F2.8 Fisheye | 2 Alien Bees 1600 | Alien Bee 400 | 580 EXII | Cybersyncs
| Latest registered member is ANebinger 1059 guests, 166 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
