Thread started 22 Feb 2010 (Monday) 08:50
7D grip - battery charging question
GyRob
Feb 22, 2010 08:50 |  #1
Can you charge them while there in the grip ?
or do you have to charge one at a time with the charger.
Rob.
"The LensMaster Gimbal"
avan
Feb 22, 2010 10:19 |  #2
Like with every Canon battery: in the charger, one at a time unless you have a second charger.
1DMK4, T6s, 100-400mmL IS II, 16-35mm f4, 100mm macro
[www.pbase.com/jeelee/g​alleries (external link)
GyRob
Feb 22, 2010 10:23 |  #3
avan wrote in post #9657985 (external link)
thanks for the info might have to get another charger then.
Rob.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 22, 2010 14:20 as a reply to  @ GyRob's post |  #4
Why? When you use the camera on one battery, the other is charging. Then you exchange them, and eventually you have both charged (except for what you used from the first, when you charged the second.
Anders
codewarrior
Feb 22, 2010 14:48 as a reply to  @ apersson850's post |  #5
And when you finally have both in the grip, charge will only be drawn from one until both batteries are at the same charge. From there, they will discharge equally (per the manual).
Drowned
Joined Jun 2005
Feb 22, 2010 16:11 |  #6
Can't you get the cheap opteka charger for $20 and charge them at the same time?
http://www.amazon.com …ics&qid=1266876​654&sr=8-2 (external link)
It also comes with an extra battery but it won't display any battery info on the camera...
Canon 7D | Tokina 11-16mm f/2.8 | Canon EF 28mm f/1.8 | Rokinon 35mm f/1.4 | Canon 100mm Macro f/2.8 | Canon 430EX II
www.snaptastik.com (external link)
1,654 views & 0 likes for this thread, 5 members have posted to it.
1473 guests, 130 members online
