Hi,
I am looking to round out my zooms on full frame. I am currently working with the 17-40 F/4L and the 70-200 F/4 ISL and am completely content with those two extremes. I want to add a fast standard zoom to fill the gap and I am debating between the Tamron 28-75 and the 24-70L.
I have owned both the 24-70L in the past (should have never let it go!) and I've been through several copies of the Tamron (with quite a bit of copy variantion) that I have used mostly on crop bodies. I have borrowed two different copies of the Tamron and used them on my 5D - one had dreadful performance and the other was quite good. I have also rented the brick once for use on FF and it delivered good results.
So fullframe users... what are your thoughts on using the Tamron on your FF bodies? The good, bad, and ugly. Can it perform well on FF? Autofocus speed aside, are you finding it accurate and sharp from wide open? Do you find corner performance to be unsatisfactory?
*** subnote - I enjoy the lower cost and size/weight savings the Tammy affords over the Brick -I can buy the brick, or I can buy the tamron + another lens I've been lusting after (either the 35L or 135L).
Cheers!
