Yet another Hockey photo getting better but still lacking. Shot @ 1/640 f4
primnumbers Member 155 posts Joined Feb 2010 Location: Kingsville, Missouri More info | Feb 24, 2010 00:59 | #1 |
skydiver_8 Senior Member 362 posts Likes: 2 Joined May 2009 More info | Feb 24, 2010 01:12 | #2 no photo ===============
Feb 24, 2010 01:19 | #3 skydiver_8 wrote in post #9671038 no photo I could not get the photo to load at first. In fact I always have trouble load photos on here Eugene Nowaczyk
Rich1884 Member 101 posts Joined Jul 2009 More info | Feb 24, 2010 01:34 | #4 What focal length was this taken at?
Feb 24, 2010 07:09 | #5 Rich1884 wrote in post #9671115 What focal length was this taken at? 200mm Eugene Nowaczyk
dwayne.evelyn Mostly Lurking 19 posts Joined May 2009 More info | White Balance is a little to blue, looks soft in the focus as well.
Feb 24, 2010 09:56 | #7 I can not figure out why the focus is a tad soft, the whit bal looks great on main PC with calibrated monitor, does look a bit blue on lap-top. Any sugestions on the focus? Eugene Nowaczyk
sadler21 Senior Member 306 posts Joined Oct 2006 More info | Focus is on the boards, although still slightly soft there too. Also seems rather dark. WB seems OK? -Chris
cstewart Goldmember More info | Feb 24, 2010 10:28 | #9 Eugene: Please Check Out My Work at:
Feb 24, 2010 10:44 | #10 cstewart wrote in post #9672911 Eugene: What is your focus set up? Hopefully your are using AI servo, Center point focus and have focus start set to work with your back * button or AF-ON button and NOT with half-press of shutter. If you are shooting center point, then it looks like it picked up focus on boards (high contrast there of signs and white) and not on players. It is important to try and keep that center point on your main subject. You can then crop for composition later. If you are using half-press shutter to engage AI servo, learn how to move this to the back buttons (Custom Fn IV on 40D...search for threads on here about "back * button focus" or "Custom Fn IV" etc to learn more). Takes a bit to get used to but much better for shooting sports. As to lighting, if this was shot with your 70-200, drop aperture to f3.2 and you will brighten up things much better (assuming all other things stay same). Or simply adjust exposure in post processing. Very good words of wisdom, will try to set the AF tothe back instead of half press shutter, You know I shot @ f2.8 and things were not as sharp as in this current photo, so moved to f4, but have not tried other f stops yet. Thank you Eugene Nowaczyk
cstewart Goldmember More info | Feb 24, 2010 12:47 | #11 primnumbers wrote in post #9673018 Very good words of wisdom, will try to set the AF tothe back instead of half press shutter, You know I shot @ f2.8 and things were not as sharp as in this current photo, so moved to f4, but have not tried other f stops yet. Thank you Eugene I find my copy of 70-200f2.8L is sharper at f3.2 than wide open at f2.8. As such I try and shoot 3.2 or higher when light permits (not often in hockey rinks I shoot in!) Please Check Out My Work at:
| Latest registered member was a spammer, and banned as such! 2766 guests, 180 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
