Thread started 24 Feb 2010 (Wednesday) 22:40
Celestial mount search
stevefossimages
Feb 24, 2010 22:40 |  #1
First, my apologies. No doubt this has come up before, but I haven't had any luck finding what I'm looking for.
And that is a camera tripod head that tracks with the earth's rotation (I'm assuming it'd be battery operated or plugged into an electrical socket) so I can take long exposures of the heavens (mostly wide- to medium-angle) without motion blur.
I've done a lot of searching online with less than fruitful results.
Thanks in advance for not ripping on me if I've been boneheaded in missing previous topics on this, and for helping a fella out.
Steve Foss
Quantum in me fuit
For weddings, reunions, workshops, Realty and guided wilderness photo excursions: www.stevefossimages.co​m (external link)
Klaus ­ Meister
Feb 24, 2010 22:58 |  #2
stevefossimages wrote in post #9677583 (external link)
From what I understand this is a very good camera mount setup for astro imaging.
http://www.sciencecent​er.net …h/kenko/skymemo​/track.htm (external link)
Nighthound
Gallery: 224 photos
Best ofs: 24
Feb 24, 2010 23:04 |  #3
No apologies necessary Steve, glad to help.
If you want something portable for a camera and lens outfit the Astrotrac is a good choice. Though the price my seem steep, the alternative would be a german equatorial mount that would be far less portable but serve the same purpose. The Astrotrac has less load tolerance than most equatorial mounts but is more than sufficient for a DSLR and the lens ranges that you mentioned.
Astrotrac site. Scroll down and note that there is a polar alignment scope available which I highly recommend. A valuable tool for accurate alignment and will make set up much quicker and less frustrating.
http://www.astrotrac.c​om …e&product=TT320​X&p=tt320x (external link)
US dealer, very reputable company.
http://www.optcorp.com​/product.aspx?pid=1202​6 (external link)
A bit more pricey unit but the Takahashi name is undeniably top notch for astro gear.
http://www.optcorp.com …w=Takahashi%20t​eegul&st=2 (external link)
I hope this helps some and if nothing else you can google these and read more on them and their reviews. Good luck and keep us posted.
Steve
Adrena1in
Feb 25, 2010 02:37 |  #4
How much are you looking to spend, Steve? Do you like building things? Because for wide-angles, a Barn Door Tracker (external link) might be an option, and basic ones can be home-made for very little.
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
stevefossimages
Feb 25, 2010 07:44 |  #5
Thanks folks! I could spend a fair amount of change on it. The Astrotrac is within my price range, while the Takahashi may be but is probably stretching it a bit.
On the other hand, I'm a handyman, carpenter and woodworker, so the barn door tracker looks pretty darn good for what I have in mind.
Steve Foss
Quantum in me fuit
A.S.I.G.N. ­ Observatory
...For the future of mankind
Gallery: 15 photos
Feb 26, 2010 00:12 |  #6
Try some of the smaller EQ mounts from Orion if you only want to put a camera on top. Otherwise, get a bigger one with a telescope and plug your camera on the end.
http://www.telescope-service.com/OrionUSA/m​ounts/mounts.html (external link)
Baz.
Builds By Baz website http://www.buildsbybaz​.com (external link)
chris.bailey
Joined Jul 2003
Feb 26, 2010 03:01 |  #7
The Astrotrac is a nice piece of kit and very portable. Am considering one myself as lugging a big EQ6 to a dark site is really a no-no. Just make sure you get a pan head as it really is too much for a ball head. Saw a setup using the Astrotrac portable pier a while back and that is very nice indeed. With the wedge on top it takes the Astrotrac to a whole new level. Guy I saw using one was having no problems with 5 minute subs using a 200mm lens.
VIGER
Joined Sep 2009
Feb 26, 2010 06:59 |  #8
Hi,
I am using the SkyMemo for the last two years and I am more than plase with it. The Heq5 pro now is used with the Mewlon. Construction is solid. Precise. The polar finder is a work of art.
IMAGE: http://www.sciencecenter.net/hutech/kenko/skymemo/3-2.jpg
(from web site)
I have great results with it. It's light and portable. I can image with it using my 5D and grip - lenses from 17mm to 400mm.
My grain of photon ; )
Michel
Perception is reality
Canon 7D. - 5DmkII . 20D IR 10D - Canon 10-22mm - Canon 17-40mm L. 50mm 100mm /100mm macro , 200mm L ,70-200mm L Canon 400mm L - Takahahsi Mewlon 210. SkyWatcher 120ED
2,903 views & 0 likes for this thread, 7 members have posted to it.
652 guests, 125 members online
