FORUMS Photography Talk by Genre Macro Talk
Thread started 01 Mar 2010 (Monday) 10:06
Error Using Tubes
bruceq
Mar 01, 2010 10:06 |  #1
I know I saw a thread about this issue before but for the life of me I can't find it now.
I'm having an issue using my T1I, EF100 f2.8 and extension tubes. Everything is fine with 2 tubes but if I add a 3rd, I recieve an error. I've tested with multiple light sources and have the same outcome.
The tubes are Pro Optic from Adorama... should I return them and get Kenko? Or is something else at fault?
Thanks in advance for any help.
Cameras - 5D MkII/Grip, 7D/Grip, T1i/Grip
Lens - EF-S 10-22, EF-S 18-55, EF 35-70, EF-S 55-250, EF 17-40L, EF 24-105L IS, EF 70-200 2.8L IS, EF 70-210, EF 100-400L, Sigma 150-500 OS, EF 100L IS, EF 180L, EF 85 1.8, EF 50 1.8
LordV
Mar 01, 2010 12:51 |  #2
Is this with any combination of 2 tubes is ok ?
and your certain the tubes are locked properly ?
I'd just check the contacts on the tubes, camera body and lens look ok.
Have heard it claimed you are supposed to use tubes in size order with the largest tube first on the camera body but never seemed to affect mine, although I have had the odd error when using 3 normally solved by taking them off and reseating them.
Brian v.
Macro Hints and tips
bruceq
Mar 01, 2010 13:00 |  #3
Yea, it's happening with any combination.. as long as it's not all 3.
Right now my batteries are charging but I'm going to try installing 1 tube on the body and 2 on the lens, then putting them together and see if it makes a difference? I'm really bummed at this point.
bruceq
Mar 01, 2010 18:31 as a reply to  @ bruceq's post |  #4
Ok, after charging the batteries I did some more testing. I used the 3 tubes in various combinations of order and had the same result. Any 2 tubes works great... add the 3rd tube and I get the ER01 code.
Has anyone else had this issue? Should I assume there is something wrong with the Pro-Optics tubes from Adorama and exchange them for Kenko's?
JEC
Mar 01, 2010 18:37 |  #5
I'm just guessing, but perhaps the weight of the lens is causing the tubes to flex just a bit. Perhaps just enough to break the electrical circuit.
Maybe a thorough inpection and "tweaking" of each electrical contact on each tube section will solve your problem.
I can't imagine that the actual "number" is tubes matters. I use 6 or 7 at times.
Usually they are between a center supported Tamron 180mm macro lens one one end and a heavy camera on the other. I see the whole assembly flex a bit when I put it together, and I've at times wondered if electrical continuity will remain.
So far, so good.
LordV
Mar 02, 2010 00:15 |  #6
Certainly sounds like you have a contact problem going on. I've not seen this reported as a problem with the pro-optics before so would guess they are defective in some way.
Brian v.
bruceq
Mar 12, 2010 19:01 as a reply to  @ LordV's post |  #7
Well I returned the Pro Optics to Adorama and bought the Kenko tubes instead. I'm very pleased to report that there are no issues with the Kenko's at all! :D
LordV
Mar 13, 2010 00:21 |  #8
bruceq wrote in post #9785253 (external link)
Odd re the pro-optics- they must have a bad batch - someone on another forum reported a similar problem after yours. Glad you've got a working set now.
Brian V.
dicklaxt
Mar 13, 2010 03:29 |  #9
If any two out of three worked properly and all three gave a problem then the problem has to be with flexing/movement separating the contact at the tube nearest the camera from the contact on the camera .It has to be a misfit on the mating of devices.I suspect a quality control problem with the computer program that is controlling the manufacturing process of the tubes,the tolerances are a few thousands out of spec.
The weight of the lens in this setup is the only thing that comes to play,I'll bet a light weight lens would have worked but that doesn't make it right ,the problem is still with the tolerances.
dick
1,146 views & 0 likes for this thread
Error Using Tubes
Latest registered member is downhillonwater
1051 guests, 353 members online
