Thread started 01 Mar 2010 (Monday) 11:46
DPP Sharpening Amount
tmalone893
Gallery: 54 photos
Mar 01, 2010 11:46 |  #1
My usual work flow is download raw files and convert to jpg via ACR/photoshop elements 7. Crop, color correct, and sharpen. I usually USM at 75.2.3
I start yesterday playing around with DPP 3.8. I was having to move the sharpening slider in the 120-200 range, and some up to 300. Is this normal or have I gone overboard. The pictures look sharp with those amounts, even at 100% view but I haven't had any printed yet. Just looking for some others to verify the amount of sharpening they do. Thanks!
MaxPreps Profile (external link)
https://www.instagram.​com/theronmalone/ (external link)
Lowner
"I'm the original idiot"
Mar 01, 2010 14:45 |  #2
Theron,
For my taste, yes, totally overboard. On the rare occasion I sharpen in DPP I always use the RAW slider which is never pushed above 3 and is generally left at 2.
My preferred sharpening routine is a three stage process using the Photokit Sharpener plug-in. I do a very gentle capture sharpen which simply corrects the anti-alliasing filters softening effect, then whatever creative sharpening the image requires during post-processing (which can be anything -I don't have any standard process for this) and finally a pre-print sharpen based on the pixel count of the image and the prints physical size which overcomes the softening during the printing process.
Richard
J_R2
Mar 02, 2010 10:24 |  #3
tmalone893 wrote in post #9706883 (external link)
If you are working with RAW-files Canon suggests you use the RAW tab sheet for most of your editing.
" For functions other than tone curve adjustment and automatic adjustment, we recommend adjusting RAW images using the same functions available in the [RAW] tool palette."
"the [RAW] tool palette is similar to the camera setting."
The RAW slider has a different algorithm than the more global sharpening in the RGB tab sheet. In the RAW tab sheet I set the sharpening to 2-3 most of the time.
JR
JeffreyO
Mar 03, 2010 15:34 as a reply to  @ J_R2's post |  #4
I have a somewhat tangential question. When I use RAW in DPP I always seem to go to 7 for sharpening. I know that sounds like a lot but I always end up there. If I set this in camera will that work the same way so I don't have to spend time adjusting it in DPP? Thank you.
XSi with grip, Sigma 18-55 f/3.5-5.6, Sigma 28-70 f/2.8, Canon 100 f/2.8 macro, old but great Canon 300 f/4 L, 430 EX II, Quantaray 900W, broken tripods, White Lightnings, many accessories--former pro film, quit, now back into it for fun
Flickr (external link) - Picture Zealot blog (external link) (Old)
tzalman
Fatal attraction.
Mar 03, 2010 15:45 |  #5
JeffreyO wrote in post #9722284 (external link)
Camera settings such as sharpening, contrast, sharpening, etc. are for jpgs only. However, the camera settings are recorded in the file metadata, which is read by DPP and the DPP sliders are preset to the equivalent positions.
Elie / אלי
JeffreyO
Mar 03, 2010 15:58 |  #6
tzalman wrote in post #9722356 (external link)
I only shoot RAW. So if I understand you, camera settings won't affect RAW images at all?
tonylong
...winded
Gallery: 60 photos
Mar 03, 2010 18:39 |  #7
The camera settings act like a preset in DPP for the Raw converter. They don't change the Raw data and can be freely tampered with until you Convert and Save.
Sharpening in your Raw converter is partly a matter of taste but with a concern to bear in mind. If you plan to process your Raw and then Convert to a final output (jpeg, print, etc) then sharpen it as much as you like, making sure to examine it at various levels of enlargement to ensure that something doesn't look garish or that you don't get artifacts that will bite you. Then, be happy.
However, if the image you are working on is going to be sent to Photoshop or another full-featured editor, then there is good reason to only apply a minimal amount of "capture sharpening" to just bring the needed bits of detail/contrast out of the naturally somewhat soft Raw capture, and then in Photoshop apply its more exacting sharpening methods where you can at the very least apply a mask and selectively apply sharpening and/or noise reduction.
Since I don't normally resort to Photoshop for my images unless I have a specific special goal in mind, I work with my sharpening and NR tools in Raw to, as much as I can, "get it right". Sometimes a scene/subject can take more, sometimes less -- just try to get a feel of things as your go.
Tony
tmalone893
Gallery: 54 photos
Mar 03, 2010 21:45 as a reply to  @ tonylong's post |  #8
I usually shot RAW as well but the sharpening slider I was referring to is in the RGB tab. This is the slider that I was moving 1/2 to 2/3 to get a nice sharp image.
René ­ Damkot
Mar 04, 2010 07:00 |  #9
JeffreyO wrote in post #9722445 (external link)
DPP will use the camera settings as "default starting point".
If you set sharpness to 7 in camera, the file will open in DPP with sharpness set to 7.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,952 views & 0 likes for this thread, 7 members have posted to it.
748 guests, 124 members online
