Yes, that 28-135 is a good starter lens. The only drawback is that it won't give you a terridbly wide angle of view, so you'll have to step back a little to squeeze the whole car into the picture. For night/low light shots you might want to look into a tripod, but more importantly you should get a good introductory book on the basics of photography. Many like the "magic lantern" series, but I personally liked "the digital field guide" (not sure if it is still in print).
In either case, you will have a little bit of a learning curve and then you should be in pretty good shape to see what type of lens you might really want to get as your second.
Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
Formerly: 80D, 7D, 300D, 5D, 5DM2, 20D, 50D, 1DM2, 17-55IS, 24-70/2.8, 28-135IS, 40/2.8, 50/1.8, 50/1.4, 70-200/4IS, 70-300IS, 70-200/2.8, 100 macro, 400/5.6, tammy 17-50 and 28-75, sigma 50 macro & 100-300
