Thread started 02 Mar 2010 (Tuesday) 14:08
Night photography??
Lulula
Mar 02, 2010 14:08 |  #1
Ok.. here's the thing, I'm going to be photographing the opening ceremony for an archery championship, and I'm worried, for two reasons. First, it's going to be at night, AND it's going to be outdoors.
I'm not used to night photography (literally) and I have a few questions.
My camera is a 50d, and I recently bought an external flash. (bear with my please.. I'm still a beginner :neutral:)
My first question, what settings should I use?
How to use my external flash, and how to aim it at the subject I'm shooting?
If I want to shoot continuous shots at night, how does that work?
Any useful tips are MOST welcome!! Keeping in mind that this is going to be the first time I shoot at night -?
Thanks!
Mocows
Mar 02, 2010 14:16 |  #2
Do you have a tripod? What flash did you get? What lenses are you planning on using?
If you don't have to move much, a tripod would help imo.
The flash is important cuz depending on your definition of "continuous shooting", not all flashes can withstand rapid fire shots without overheating. I'm sure lenses would be important to know as to calculate out some settings you could try.
7D | XSi + Phottix Grip | 400 F/5.6 | 70-200 F/4 | Sigma 30 f/1.4 | Sigma 10-20 f/4-5.6 |430ex | Horusbennu C-2830V | Photo Clam PC-33
flickr gallery (external link)
Lulula
Mar 02, 2010 14:20 |  #3
Yes I do have a tripod. The flash I got is a Speedlite 270ex, and I'm planning on using my EFS 18-200mm zoom lens.
DragonDan
Mar 02, 2010 14:24 |  #4
My first though is to not use a flash - that's a sure way to make people (and the contestants) angry with you. So that leaves it up to fast glass - meaning for your use, maybe a 70mm-200mm f2.8. The lower f number means how much light the lens will allow to hit the camera's sensor. You can rent these lenses at your local camera shop.
For the camera settings, you are probably going to have to use high ISO's to keep the shutter speed high. I'm not familiar with what it would take to freeze an arrow in flight, or to get crisp focus on the people, maybe 1/250 to start?
Can you get to the site a day early and do some test shots? A tripod is a must, as well as shooting in RAW for maximum control over the final image.
Canon EOS 50D gripped; Tokina 11-16mm f/2.8; ∑30mm f/1.4; ∑105mm macro; 70-200mm f/4L; 430EX II
5x5 ­ photography
Mar 02, 2010 14:30 |  #5
I imagine this is going to be a tough shoot with your gear.
The 18-200 lens is not a bad lens but it is slow (min aperture at 18mm f/3.5 and using 200mm at f/5.6 will require a powerful flash).
The 270Ex will sync at 1/250th but max range at 100 ISO is about 25 feet (that is with a 50mm f/1.4).
What size are the images going to be? I would shoot RAW, use the flash, look for a faster lens. The 17-55 f/2.8 would be a better choice or the 24-70L f/2.8 for a longer reach. If you could get away with using a prime look at the 28 or 85 f/1.8 for wide ot telephoto. The 50mm f/1.8 is a good lens and cheap.
You could always rent a lens and maybe a 430 EXII flash if using a flash will not be a problem.
My firearms review site. http://rangehot.com/ (external link)
emtp563
Mar 02, 2010 14:31 |  #6
Lulula wrote in post #9714988 (external link)
You shouldn't have gotten that flash- it's not very powerful. It "might" be ok if you're shooting subjects extremely close to you, but if what you're shooting if more than 25 feet away, I'm afraid you're wasting your time with that flash.
Your lens isn't the best either. However, you should be ok with it. It's not the best lens out there, but it's not the worst either. F/3.5 is relatively fast at 18mm, but as soon as you start using 200mm, your maximum aperture goes to f/5.6- that's too slow for what you're attempting to shoot. Set your camera to Av mode and open your aperture wide open. On that lens, it's f/3.5. On the 50D, don't be afraid to use a high ISO. You should be o.k. using ISO 1600-3200 on that camera.
One thing to keep in mind is camera shake, if you're zoomed to 200mm, you'll need a shutter speed of at least 1/320 to avoid camera shake. Adjust your ISO accordingly to keep the shutter speed > 1/320.
I'd try to go flashless and reserve the use of your 270EX for close-up shots.
*cameras: Canon 1D Mark III | Canon 1D Mark II | Canon 1D "Classic" | Canon S95
*lenses: Canon 16-35L f/2.8 | Canon 24-70L f/2.8 | Canon 70-200L f/2.8 IS | Canon 1.4x TC II
*accessories: Canon 580EX II/430EX | Quantum Turbo SC | CP-E4
http://www.cyclingcapt​ured.com (external link)
http://www.facebook.co​m/cyclingcaptured (external link)
sdipirro
Mar 02, 2010 14:40 as a reply to  @ DragonDan's post |  #7
OK, taking a step back for a moment, although this is taking place at night, obviously they're not shooting arrows in the dark and the competition will be illuminated...just not that well. So let's just say that the lighting won't be very good. You need some idea of the distance between you and the subjects. The 270EX doesn't have a long reach. It's not bad, but if you're pretty far from the action and shooting at 200mm, the flash might not do you much good. Once you slide the flash onto the hotshoe of the camera, you would position the flash head to point straight ahead for maximum illumination.
The tripod/monopod is only useful to reduce camera shake if you're shooting at slow shutter speeds. I doubt you'll be doing that if you're trying to capture arrows in flight. If you want to capture night scenes with the natural light of the scene, then you might want a tripod to shoot with a slow shutter speed.
What you'll definitely want to try is the biggest aperture your lens will allow, a shutter speed that will freeze action (1/250 or faster), and a high ISO setting to get the proper exposure without a flash. If you're close enough to the action to use the flash, you can back down on the ISO setting.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
MichaelBernard
Mar 02, 2010 15:25 |  #8
DragonDan wrote in post #9715007 (external link)
This, but I'd say go with a fast prime, like a 85mm f/1.8. Imagine flashing the archers every time they release...it's going to get old quick. Crank the iso a bit, open up the lens, let it fly.
http://www.Michael-Bernard.com (external link)"I think that there will be people disappointed in any camera short of the one that summons the ghost of Ansel Adams to come and press the shutter button for them." -lazer-jock
ilumo
Mar 02, 2010 15:32 |  #9
AudibleSilence wrote in post #9715385 (external link)
+1 flash them a few times, they might turn their bows on you... :o
Body: Sony a7R IV
Glass: 50mm f/1.8 | 35mm f/1.4L USM | 16-35 f/4.0 IS USML USM | 24-70 f/2.8L II USM | 24-105 f/4.0L IS USM | 70-200 f/2.8L II IS USM | 85mm f/1.4L IS USM | 100mm f/2.8L IS USM | 24mm f/1.4GM | 70-200mm f/2.8GM | Samyang 85mm f/1.4 | Voigtlander 10mm f/5.6
Accessories: 430 EX II, 600 EX, tripods, umbrellas, and other goodies.
Tarzanman
Mar 02, 2010 15:53 |  #10
If you are shooting any kind of movement at night that requires fast shutter speeds (anything faster than 1/120) then you're going to need:
• A tripod
• Fast prime lenses with large apertures (f/1.8 or larger)
• ISO cranked up to the maximum range that will still give you good photos (1600 or more)
• Noise ninja or some other noise management software
• A good working knowledge of how to work your camera's light metering and how to bracket.
A flash (even a weak one) is still a good idea. You might be able to get some good rear-curtain sync shots.
How well the venue is lit will play a HUGE role in how your photos turn out. If they are doing any kind of professional video then you'll probably have good enough light to shoot fast action.
Lulula
Mar 02, 2010 16:11 |  #11
ilumo wrote in post #9715431 (external link)
lool!! It's a good thing this is only an opening ceremony, the contestants won't be playing on this day, the matches begin on the second day. So yea.. I won't be needing continuous shots for arrows, I just thought it would be a good way to capture the event.
Unfortunately, there are no shops to rent lenses where I live, so I'm going to have to work with the gear I have.
Tarzanman, I think the venue will be lit pretty well, it's the African championship, so I guess there will be a TV crew filming.
Thank you all for your tips!!! They've been really helpful! I'll print this whole thread and the replies and keep it with me in case I want to get back to it :D
themadman
Mar 02, 2010 16:14 |  #12
Lulula wrote in post #9715698 (external link)
Save a couple trees and just bookmark it =P
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
MichaelBernard
Mar 02, 2010 16:15 |  #13
Steal their light :) They will undoubtedly have the shoulder mounted light or a few continuous lights going...stand behind and to the side... I used this trick while documenting the creation of a tv commercial when all I had was my lowly f/2.8 lens.
themadman wrote in post #9715712 (external link)
Paper is already created, if she uses her PC (power) she's burning coal or using nuclear power... It always comes from somewhere :p
Lulula
Mar 02, 2010 16:20 |  #14
I would.. but I'm not going to drag my laptop along with me through the whole event, maybe I could just write down the important notes in my note book :D how about that? =P
Lulula
Mar 02, 2010 16:22 |  #15
AudibleSilence wrote in post #9715721 (external link)
Good idea!!!!!!!!!
3,455 views & 0 likes for this thread, 22 members have posted to it.
Night photography??
2763 guests, 158 members online
