First soccer shots with my new T1i (first time with DSLR ever). I rate them "meh", but feedback will help me learn quicker...thanks in advance for your C&C.
1.
2.
Alikat Member 156 posts Likes: 1 Joined Jan 2010 Location: British Columbia More info | Mar 02, 2010 14:28 | #1 First soccer shots with my new T1i (first time with DSLR ever). I rate them "meh", but feedback will help me learn quicker...thanks in advance for your C&C. 2. Gripped Canon T1i with Canon EF-S 18mm-55mm and Canon EF-S 55mm-250mm lens kit, Canon EF 50mm f1.8 II, 430 EXII
Mar 02, 2010 14:29 | #2 You might need a faster lens or try upping the iso they both are very soft. Canon 5DSr Canon 5D MK4 Canon 5D MK2 17-40 L 16-35 2.8 L Canon 70-200 2.8 IS L Canon 300 2.8 Canon 600mm 4.0 IS LCanon 50mm 1.2 Canon 85mm 1.8Canon 600EX
Mar 02, 2010 14:34 | #3 FstopMiami123 wrote in post #9715042 You might need a faster lens or try upping the iso they both are very soft. Armadno After shooting this and some junior hockey in the first two days with the camera I completely understand why "kit lenses" are just that Gripped Canon T1i with Canon EF-S 18mm-55mm and Canon EF-S 55mm-250mm lens kit, Canon EF 50mm f1.8 II, 430 EXII
Mar 02, 2010 14:35 | #4 Looks like you missed focus on both.... tell us about your AF Points... center? One Shot? AI Servo? Canon 5dmkIII, Sigma 15mm f/2.8FE; 35mm f/1.4; Canon EF70-200 f/2.8L IS II; --- YN560 x 7
Mar 02, 2010 14:47 | #5 va_rider: Gripped Canon T1i with Canon EF-S 18mm-55mm and Canon EF-S 55mm-250mm lens kit, Canon EF 50mm f1.8 II, 430 EXII
Fosters Member 55 posts Joined Jan 2009 Location: Belleville, IL ->St. Louis, MO More info | Mar 02, 2010 14:53 | #6 One pet peeve of mine (that my wife can't stand), is that I typically delete any shot that has the back of someone. Not always (but in general) someone's back doesn't "tell a story." I'm not as good as most on here, but that is one of my picky points.
cpo13 Senior Member 264 posts Joined Apr 2005 Location: Seattle, wa More info | Mar 02, 2010 14:56 | #7 As others have said you need to up the shutter speed for soccer, so assuming f5.6 is the best your kit lens can do at the long end I'd use Av at 5.6, then adjust ISO upwards until you get at least 1/400, (preferably higher). Chris
Mar 02, 2010 14:58 | #8 for AF, I'd be using AI Servo for action like this... if you're using One Shot, by the time you set the focus, whatever you set it on is gone... and you're left focused on the grass somewhere... Canon 5dmkIII, Sigma 15mm f/2.8FE; 35mm f/1.4; Canon EF70-200 f/2.8L IS II; --- YN560 x 7
Mar 02, 2010 15:00 | #9 Fosters wrote in post #9715189 One pet peeve of mine (that my wife can't stand), is that I typically delete any shot that has the back of someone. Not always (but in general) someone's back doesn't "tell a story." I'm not as good as most on here, but that is one of my picky points. You did capture the ball in your 1st shot, so my comment might not apply in that case. :P Have fun, and I would recommend reading a few books. I believe it is Understanding Exposure that is highly recommended. Josh Thanks, I've got that book on request at the library, been reading a few others I've purchased. I don't know why, and this sounds retarded, but I never thought of shutter speed as linked to focus. hmmmm...shows the gaps in my knowledge base already. Gripped Canon T1i with Canon EF-S 18mm-55mm and Canon EF-S 55mm-250mm lens kit, Canon EF 50mm f1.8 II, 430 EXII
Mar 02, 2010 15:01 | #10 cpo13 wrote in post #9715207 As others have said you need to up the shutter speed for soccer, so assuming f5.6 is the best your kit lens can do at the long end I'd set Av at 5.6, then adjust ISO upwards until you get at least 1/400, (preferably higher). Also, try to find somewhere lower to shoot, (on the sideline either sitting or kneeling if you can). Will make the players stand out much more than shots from above. Getting the timing right so you have the ball/face and/or peak action will usually come with practice, so shooting lots and posting here for c&c often will get you there. Good luck. Good points, all of them. This park is set up strangley and the opposing team's coach and I have gotten "into it" a few times, being the Regional Cup Final game I was avoiding being near him at all costs (as were almost all the parents). She plays 6 days a week so I will get lots of practice and put these points into practice. Awesome feedback, thank you! Gripped Canon T1i with Canon EF-S 18mm-55mm and Canon EF-S 55mm-250mm lens kit, Canon EF 50mm f1.8 II, 430 EXII
Mar 02, 2010 15:05 | #11 va_rider wrote in post #9715219 for AF, I'd be using AI Servo for action like this... if you're using One Shot, by the time you set the focus, whatever you set it on is gone... and you're left focused on the grass somewhere... As far as how fast is fast ... depending on what you're shooting, you can do a little math if you're so inclined.... figure a soccer ball is moving at 40mph... 40mph is equal to 58.6 feet per second... so, in 1/250 of a second, the ball is moving .235 feet, or about 3 inches.... Looking at the first picture... that seems about right.... so.. using math, you can figure out how fast you have to go to stop motion... next step is once you have the speed correct to stop motion, you'll have a very dark picture at the settings you're using now... so, you'd have to open up your aperture a bit to let in some more light... with the distances you're shooting, 5.6 is likely the lowest you'll get on your current lens... so, a faster lens would suit this type of shooting a bit better... something like a 135mm f/2 ... or... better lighting will allow a faster speed.... buy those poor girls some nice bright stadium lights. ... or, the next compromise is increasing the ISO... but the shots will be grainier... ISO100 would make you have to go to a slower shutter speed... but ISO 1600 would let you bring the shutter speed much faster... with the tradeoff of graininess.... Yes, I actually learned about ISO in a brutal way at a cheerleading competition (gym lights just stunk!) and am adverse to the graininess and try to avoid it where I can. Gripped Canon T1i with Canon EF-S 18mm-55mm and Canon EF-S 55mm-250mm lens kit, Canon EF 50mm f1.8 II, 430 EXII
| Latest registered member was a spammer, and banned as such! 2608 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
