Thread started 03 Mar 2010 (Wednesday) 18:35
430EX and Cactus V2s
javig999
Mar 03, 2010 18:35 |  #1
I acquired 285HV's along with a Cactus V2s set and they had been working fine with the 285 HV flashes. I had not really tried it, but decided to test the 430 EX as it has better manual setting so I put it on the receiver. It did not fire in Manual mode. moved it back on the hotshoe a bit and fired for about 5 shots then stopped again. Tried it on other reciever and worked better, but still inconsistent at best. Put the 285 back on it - fired no problem.
Now, the 285's are not firing consistently, but I think it could be low batteries -the indicator lights are very dim, and getting the Tx closer to the Rx seems to help. Could it be the 430 EX is more sensitive to battery levels in the V2s?
Can any 430EX/V2s users chime on on this? I was thinking of getting a 3rd V2s so I can use all 3 speedlites at once, but I prefer to see if the 430EX/V2s combo is not viable. Getting new batteries for Tx and Rx tonight and will report, but I guess a 3rd 285HV is the cheapest option if the 430 will just not work on the V2s?
7D | 8mm 3.5 FE | EF-S 10-22 | EF-S 17-55 2.8 IS | EX DC 30 1.4
EOS R | Samyang 14 2.8 | Sigma 15mm f2.8 DFE | RF 16mm | Art 20/35/50/85 f1.4 | EF 100 f2.8 Macro | EF 135 f2L | EF 70-200 f2.8L IS | Sigma C 150-600
MT ­ Stringer
Mar 03, 2010 18:54 |  #2
I went through very similar senario a couple of years ago. Frustration set in and I threw them in the trash. Bought a set of El Skyports and they worked great. Now I am using Cybersync's and couldn't be happier. I have thousands of pops shooting basketball with strobes, a 580 EX II and a 540EZ. everything works together with no problems.
CST transmitter and CSRB receiver for each light.
MaxPreps Profile (external link)
My Gear List
bigbearbear
Mar 03, 2010 23:44 |  #3
Hello, I have 2 sets of Cactus V2s. They fire my ABR800 ring flash consistently but when using with my Canon 430EX flash, I've found that if I mount the 430EX directly on the hotshoe of the V2s receiver, the flash will sometimes go crazy and fire continuously non-stop.
What I've done is to move the receiver away from the 430EX and connect using the short PC cable that came with the v2s receiver unit. That means you'll need one of those PC-to-hotshoe (external link) adapter though, since the 430EX doesn't have a PC port.
Bigbear.
vk2gwk
Gallery: 332 photos
Mar 03, 2010 23:50 |  #4
Are you sure that all the contacts are clean? Finger grease can already interfere with the very low power levels used in the interfacing.
I have Cactus V2 receivers and they work fine with my 430EX.
My name is Henk. and I believe "It is all in the eye of the beholder....."
Image Editing is allowed. Please explain what you did!
Canon R5, R,, RF24-105/1:4 + RF70-200mm F/2.8 + RF15-35mm F/2.8 + 50mm 1.4 USM + Sigma 150-600mm Sports + RF100mm F/2.8 + GODOX V860 IIC+ 430EX + YN568EXII, triggers, reflectors, umbrellas and some more bits and pieces...
Photos on: Flickr! (external link) and on my own web site. (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Mar 03, 2010 23:55 |  #5
The V2's are notoriously troublesome with the 430ex. Back when they were the only inexpensive option there were threads constantly on the topic. The set I have work fine with any flash but the 430ex. Mine fire intermittanly and constantly or sometimes not at all. Occasionally I could get them to work but not for too long as I soon migrated to cybersyncs
vk2gwk
Gallery: 332 photos
Mar 04, 2010 00:33 |  #6
Sorry... I misread: I am using the Cactus V4. They do not give problems.
javig999
Mar 04, 2010 02:13 as a reply to  @ vk2gwk's post |  #7
Thanks for the comments all...
Tried new batteries...didn't help with the 430EX at all...fired maybe 20% of the time. The 285HV's function fine, so it would appear the 430 is not a viable flash to use with the V2s receivers. The PC to hotshoe adapter will be option 1 - I will test first and then buy the 3rd receiver. If that does not work, then a 3rd 285 would be the final option.
Have a good night!
1,465 views & 0 likes for this thread, 5 members have posted to it.
974 guests, 108 members online
