The Canon 35 f1.4L is nearly 50mm on the 1D bodies. Let's see what your coming up with. Shots from the 35f2 are welcome as well, just make sure your on a 1.3 crop body. Thank you.
pcunite Goldmember 1,481 posts Likes: 3 Joined Apr 2007 More info | Mar 03, 2010 22:24 | #1 The Canon 35 f1.4L is nearly 50mm on the 1D bodies. Let's see what your coming up with. Shots from the 35f2 are welcome as well, just make sure your on a 1.3 crop body. Thank you.
TheMoose Cream of the Crop 5,106 posts Likes: 1 Joined Jan 2009 More info | Mar 04, 2010 02:27 | #2 If you're considering the 35L, also consider the Sigma 30/1.4. It works well on APS-H and obviously it's a lot cheaper.
pinoyed Senior Member 532 posts Joined Jan 2009 Location: Maryland More info | Mar 04, 2010 07:16 | #3 https://photography-on-the.net …?p=9703038&postcount=3870 flickr
Mar 04, 2010 08:05 | #4 I already own the 35L, just wanting to chat and view images on what could easily be the standard lens for APS-H.
TaDa ...as cool as Perry 6,742 posts Likes: 3 Joined Feb 2008 Location: New York More info | Mar 04, 2010 08:28 | #5 For me, "normal" is the 35mm fov, so I use the 35L on my 5D as I don't like it as much on my 1D3. Now the ZE on the 1D3 is something I'm really digging Name is Peter and here is my gear:
Mar 04, 2010 20:51 | #6 I guess I should clarify normal for me means the ability to frame a full body 6ft person and not introduce distortion. The closest possible on APS-H is a 35mm I believe.
AlanU Cream of the Crop More info | Mar 04, 2010 22:30 | #7 I'm sending my 1dmkIII in 'cause my 35L and canon 50 f/1.4 require alot of micro adjusting. The 35L requires 20+ backward adjustments and my 50 requires 10+. All of my zooms performs perfectly. Went to the camera shop and tested a 24LmkII and 100L 2.8is and they performed horribly needing almost max backward MA. 5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Mar 05, 2010 09:41 | #8 I am having good sucess so far with my 1Dm3 + 35L combo. I will do a client shoot next week so that will really tell me.
| Latest registered member is semonsters 1460 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
