I'm looking for the ultimate traveling tripod (landscape) combo. I'm taking a 47 rough photo tour of Tibet, Xinjiang, and Western Sichuang (Eastern Tibet) -- some of the world's most remote and beautiful landscapes.
I need a very light, very flexible tripod setup up.
Currently, I have a the following tripod setup:
Feisol CT-3441S + RRS BH-25 + RSS FAS Clamp + L Plate
I had a chance to use this on a 3 month backpacking tour of asia.
Overall, I found this setup probably the lightest possible traveling setup, but I found it wasn't the best for me. First, the rubber cap on the bottom of the Feisol tripod fell off when traveling. And second, while I liked the weight of the Feilsol, I don't like how the legs don't feel very stable sometimes.
It's fine for most situations, but when compared to one of the tavelor Gitzos (my cousin bought one), there is really no comparison in terms of quality and stability. The Gitzo's twist locks are so much faster to use and they tighten better -- the Feisol tripod's locks don't tighten as much.
I also REALLY dislike the RSS BH-25. Yea, it's a good ultra light ballhead, but it's completely lacking the smoothness of one of the bigger ballheads. It worked, but I found the ballhead TOO small. The FAS clamp is subpar compared to the larger RSS clamps.
I used a 5D +17-40 OR 70-200L with the setup.
In short, the setup I had was ultra light, but it was never really "comfortable" for me to use. So, it's time to upgrade and replace the setup. It thought I could save money on a gitzo with the Feisol, but it turns out it's a decent budget replacement, but it's not the same at all. I'm upgrading the entire tripod setup now.
I'm seriously considering buying the Gitzo 1541T Tripod + Markens Q3T (updated version) ballhead + RRS PCL-1 clamp (I will use this as the actual clamp) + RSS L Plate.
My intended setup to use with this:
Canon 5D MkII
17-40L
70-200L 2.4
85mm 1.2 I (if I can afford it)
50mm 1.8
Can anyone comment on my new travel tripod setup? The Gitzo 1541T Tripod + Markens Q3T is WELL established travel setup on this forum -- probably the most popular setup for ultra lightweight travel. I;ll be taking a lot of landscape shots high high in the mountains on rough terrain, so i like the idea of directly attaching RRS's leveling clamp (PCL-1). With that clamp on, you don't have to fiddle with the tripod to make sure camera is level...you can level off the camera in seconds -- pretty damn convenient! I also want to take quite a few panorama shots, so the leveling clamp should prove effective there. I know it's heavier than the standard RSS clamps, but by directly attaching it to the ballheads as the clamp, it doesn't add that much more weight.
Has anyone used this combo yet? And what do you guys think?
