Thread started 05 Mar 2010 (Friday) 13:14
17-55 dust?
trailguy
Mar 05, 2010 13:14 |  #1
Ok, coffee mug is cool, but I came here because I'm going to buy a 17-77 2.8 IS, and I keep reading that it sucks dust.
Where is the vacuum? Does it go onto the lens? Will a filter fix it, or is it going into the mechanical area?
Is it easy to clean? I hope this doesn't spoil my desire for this lens.
Perfectionism is the highest form of self-abuse
"Best wide-angle lens? Two steps backward"
Ernst Hass 1952
Trixster!
Mar 05, 2010 13:22 |  #2
I bought a 17-55 a year or so ago which had a couple of specs of dust on the front element. I've used a filter ever since I've had the lens and it's not picked up another single spec since. The dust does not show up on my photos whatsoever.
There are some instructions on the web as to how to go about clean the dust away from the inside of the lens - it seems like a pretty simple DIY procedure assuming you're happy to take the front of your £700 investment apart!
5D Mark II | EF 24-70 f/2.8 L | EF 70-200 f/4 L IS | EF 17-40 f/4 L | EF 50 f/1.8 | EF 1.4x II | Nissin Di866 II | flickriver (external link) | Portfolio (external link) | flickr (external link)
spamster
Mar 05, 2010 13:30 |  #3
There's these two little holes on the front close to the filter threads. I believe that's where a lot of the dust gets into the lens. Buying a filter should solve the issue or you can take it apart. Whichever you fancy :)
drumsfield
Mar 05, 2010 13:40 |  #4
I keep a filter on all my lenses and store them with the front element down.
Canon 5D MkIII | Olympus OM-D | Olympus E-P2 | 16-35L MKII | 24-70L MKII | 70-200L MKII | 85L MKII | EF 50mm 1.4 | EF 100mm 2.8 | 100-400mm L MKII | 20mm 1.7
Feedback and Full gear list
Website (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 05, 2010 13:40 |  #5
spamster wrote in post #9735502 (external link)
It is the entire front of the lens. There is that canon ringed sticker there on the front of the lens, but when you pull it off, you will see that there a few vents into the area behind the front element, and zooming the lens back and forth will eventually deposit dust there. A good UV filter will help keep the dust out and not degrade your IQ, but if you like to go filterless, just expect that in a year or so, you will need about 15 minutes and a jeweler's screwdriver to clean the dust out.
HKGuns
Gallery: 45 photos
Mar 05, 2010 13:59 |  #6
I recently sold mine because I went to a 1.3 crop. Dust was never an issue with my lens and it was one of my favorite lenses.
alpha_1976
Mar 05, 2010 14:08 |  #7
Put a filter on front and no dust will ever enter.
I know more about gear than I know about photography :p
eelnoraa
Mar 05, 2010 14:14 |  #8
Use a fitler for this lens. Mine has been good for 3+ years. It got a little dust inside, but I thought it came with it when I bought it tho. It is overall NOT worst than any non-L I have own, ie, 85/f1.8 and 28f/1.8
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
gjl711
"spouting off stupid things"
Mar 05, 2010 14:19 |  #9
This will help. Nothing like a few pics to explain the problem.
http://www.pbase.com/r​cicala/1755_is_surgery (external link)
As mentioned, the plastic ring on the front of the lens is just a sticker. It is not sealed and dust can sneak in. A filter seals up the front of the lens eliminating this route. On the positive side, if you do get dust. It is very simple to clean. Remove the label, three small Philips screws releases the front element and clean away.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
JWright
Joined Dec 2004
Mar 05, 2010 15:52 as a reply to  @ gjl711's post |  #10
It's a normal characteristic of a zoom lens that it's going to get dust in it. Any time you have a lens with moving internal elements there has to be a way for the air displaced to move in and out of the lens. This air will invariably carry dust with it. Even the addition of a filter sin't going to prevent all the dust from getting in. It will lessen the amount but won't prevent all of it. If a lens were completely sealed against dust, there would be no way you could zoom it.
John
Pete-eos
Mar 05, 2010 17:31 |  #11
I must live a very backwards life, my 17-55 is dust free, my 50mm prime and 85 f/1.8 got filled with the stuff!
whiteflyer
Gallery: 314 photos
Mar 05, 2010 19:17 |  #12
I have had a filter on since day one and never noticed any dust in mine, bought in June 2007
Perfect_10
Joined Aug 2004
Mar 05, 2010 20:02 as a reply to  @ whiteflyer's post |  #13
The only filter this lens should be fitted with is a HEPA one :)
My Gear List  :p
SiaoP
Mar 05, 2010 20:07 |  #14
They should really weather seal that lens... Put a filter on it, it'll reduce the dust intake.
My Flickr (external link) | Gear List
JeffreyG
Gallery: 42 photos
Mar 05, 2010 21:38 |  #15
JWright wrote in post #9736370 (external link)
Actually, dust generally gets into just about any lens. My 85L had a few specs in it (and it does telescope slightly with focussing) and my 85/1.8 has some dust in it and it does not change size at all.
Dust happens. I've had several lenses with a few specs and I cannot recal ever seeing an impact in the images.
2,303 views & 0 likes for this thread, 20 members have posted to it.
17-55 dust?
1228 guests, 149 members online
