ok I have the lensmate 58mm adapter for my SX10. and just got a threaded 58mm lens hood
I tried spinning the hood onto the lens mate.. it doesnt get started ...
are you supposed to just push it on flat?
scott0999 Member 173 posts Joined Aug 2006 More info | Mar 06, 2010 15:45 | #1 ok I have the lensmate 58mm adapter for my SX10. and just got a threaded 58mm lens hood Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 06, 2010 15:52 | #2 Should screw right on . . . Jon
Mar 06, 2010 16:38 | #3 I got it to go on but it doesnt feel right..I'm thinking the lensmate is to blame Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
childsuccess Member 86 posts Joined Jun 2009 Location: Mt. Pleasant, SC & Tolland, MA More info | Mar 07, 2010 05:12 | #4 I have the lensmate 58mm adapter and find it flimsy and difficult to use. If you tighten the bayonet mount to the camera too far, it will then loosen up and come off. Trying to screw a filter into its threads has been very tricky also. Not happy with it but haven't found anything else to use when I want a polarizing filter. It definitely does screw on in but requires patience and dexterity. Gear: Nikon D90, Nikkor 70-300mm, Nikon 18-55mm Tamaron 90mm Macro; Canon SX20 IS & Vivitar 383 Flash
JustShootin' Senior Member 820 posts Joined Jan 2007 Location: South Florida More info | It's better than nothing, but not very good. I believe they made it weak so people couldn't ruin their camera by trying to screw heavy conversion lenses on. I blame Canon for not treading the lens for 52 mm filters in the first place. Gary
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 07, 2010 09:16 | #6 And if Canon had threaded it for 52 mm filters and people'd tried mounting conversion lenses, damaging the camera, then whose fault would it be? The camera was not designed to handle extra weight on the front of the lens, in order to keep the zoom mechanism within reasonable weight and size limits. Jon
Mar 07, 2010 09:43 | #7 I'm glad its not just me then Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
Mar 07, 2010 11:13 | #8 got a reply from lensmate: Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 07, 2010 20:27 | #9 Should, but cheap manufacturers may not be all that careful. I've even seen filters and hoods with molded plastic filter rings, complete with mold marks. Jon
Mar 07, 2010 22:21 | #10 I've decided I'm going to use the Canon lens hood and keep a CIR-PL filter on the lensmate. with the filter it reflects the light anyway the hood shouldnt be needed when its on Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
Mar 08, 2010 12:59 | #11 I did some more experimenting Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
JustShootin' Senior Member 820 posts Joined Jan 2007 Location: South Florida More info | Mar 08, 2010 23:14 | #12 Jon wrote in post #9745434 And if Canon had threaded it for 52 mm filters and people'd tried mounting conversion lenses, damaging the camera, then whose fault would it be? The camera was not designed to handle extra weight on the front of the lens, in order to keep the zoom mechanism within reasonable weight and size limits. A great big ole WARNING against conversion lenses should have kept Canon safe from libility, just like they warn you not to get the camera wet etc. Gary
Hasitha Member 131 posts Joined Mar 2009 More info | Mar 09, 2010 11:23 | #13 scott0999 wrote in post #9745522 I have to give it a good push and turn. and then you get about 1 full turn (at most I think) and its on.. kinda disappointing but like you guys said no one else makes a 58mm adapter ![]() Well now there is another 58mm Filter Adapter for SX10 / SX20 Cameras. It's called Janco 58mm Filter Adapter Canon SX10 IS
Mar 09, 2010 11:39 | #14 Hasitha wrote in post #9760234 Well now there is another 58mm Filter Adapter for SX10 / SX20 Cameras. It's called Janco 58mm Filter Adapter Anyway did you try fixing this hood into your polarizing filter ? If that works you can use it with a UV filter I think. Also what's the name of this Hood you bought ? oh man, I should of got the Janco. I did see that, but I was assuming they were both plastic *DOH* Canon SX10 IS | 430EX | Custom OCF Cable | Lensmate & Janco 58mm adapters | Raynox DCR-M250 | Hoya HD CIR-PL | Vanguard VS-82https://photography-on-the.net …php?t=836625&highlight=s2
duckduckdog Member 113 posts Joined Feb 2010 Location: South Carolina More info | Mar 09, 2010 11:59 | #15 I've got the Bower adapter and it is metal. It works well. It is a little tough to get on, but it works. haven't had a chance to shoot with it yet, but spring is right around the corner!!! Canon SX20IS
| Latest registered member is Mihai Bucur 1154 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
