Thread started 06 Mar 2010 (Saturday) 16:21
Canon GL2 Help
Wondertwins
Mar 06, 2010 16:21 |  #1
-Hey guys, I recently bought a Canon GL2 from a POTN user for an awesome price. After talking to him and reading the manual, I found out that you CANNOT record your videos through the SD card slot and only tape. I asked the person that I bought it from and to convert your DV tapes into your computer is a long and arduous process.
-Is there any way you can record videos through the SD card slot and if you can, how do you transfer the video from the camcorder to the computer.
-If you cannot, how can you transfer the video from the DV tape to your computer without converting it into VHS/DVD then to your computer (that is what he told me).
-Also, if you do convert DV tape to your computer, is there any loss of quality in audio or video?
-Another question: what are some good high quality video editing programs?
I may be familiar with photography but I am new into videography. :oops:
Thanks in advance
(Canon 7D Gripped) (Canon 35mm f/1.4 L) (Canon 135 f/2L) (Canon 430 EXII)Flickr (external link)
Wondertwins
Mar 06, 2010 17:27 |  #2
help???
yokotas13
Mar 06, 2010 18:11 |  #3
you plug it into your computer, and use your editing software to capture it.
instruction manuals for editing programs are amazing
-Grant
[URL=http://photograph​y-on-the.net/forum/showpost​.php?p=7493258&postcou​nt=1706]Gear List
check the blog- www.wagonofdoom.wordpr​ess.com (external link)
Wondertwins
Mar 06, 2010 21:01 |  #4
It says that I need a firewire cable to transfer videos onto my computer. can someone verify this? Also, the camcorder did not come with the cd and I tried looking for the installation on Canon's website and other sites but did not come up with any results. I need to record something for my school soon and I need many questions answered.
sorry for my noobness in cinematography
RWatkins
Mar 06, 2010 21:56 |  #5
Wondertwins wrote in post #9743188 (external link)
1. Yes, you need firewire/IEEE1394/iLin​k.
2. No, you do not need the Canon CD.
I've used the Canon HV20, another DV tape based camcorder from Canon. In that case, the CD only had manuals and photo software, not a utility for the capture/editing of video.
Are you using a Mac or a PC? What are you using to edit the videos, that may help with an answer. Many times, not always, capture using DV tape is done using your editor.
Stuff and things
President – International Brotherhood of Instagram Haters
Wondertwins
Mar 06, 2010 22:22 |  #6
RWatkins wrote in post #9743394 (external link)
I am using WIndows 7 64 bit and I have Adobe Premiere CS4 and Sony Vegas Pro 9.
So you DO need a firewire cable to transfer video from the camcorder onto the computer?
RWatkins
Mar 06, 2010 22:25 |  #7
Wondertwins wrote in post #9743524 (external link)
YES, you need a firewire to do this! If you need to order one, make sure you know the connection type on the camera AND the computer. Some are 6 pin and others are 4 pin type. Oh, and this uses firewire 400, not the newer 800 standard.
If you need a cable, they are a few dollars (2-3) at monoprice.com
The programs you mention have an import feature. The time it takes is the same as the length of your video (e.g. 5 minute video will take 5 minutes to import) because it must play in real time.
Why not transfer via USB you may ask? Well, the data stream is pretty high coming off the camera since its doing it in real time, and USB 2.0 cannot handle the sustained rate like firewire can.
Stuff and things
Wondertwins
Mar 06, 2010 22:34 |  #8
So for the wire, you get a DV to Fire wire cable?
RWatkins
Mar 06, 2010 22:43 |  #9
Wondertwins wrote in post #9743587 (external link)
No, you will need a firewire cable. The thing is, there are two types of end connectors. The reason for this is space. Firewire 400 - 4 pin ports are much smaller, and are (or were) more commonly found on laptops. The 6 pin, which carry power, are bigger and are found on desktop machine and some laptops (e.g. last generation MacBook and Macbook Pros). If you have a newer Firewire 800 port, you can still connect to this.. its backwards compatible.
There is a firewire 400 - 6 pin type and a firewire 400 4 pen type.
For example, my HV20 used a 4 pin type and my macbook used a 6 pen type. You have to make sure you have the correct connector knowledge before you order a cable.
Does the firewire port on your computer look like this
(6 pin)
IMAGE: http://upload.wikimedia.org/wikipedia/commons/b/bc/FireWire_gniazdo.jpg
or this
4 pin
IMAGE: http://a248.e.akamai.net/pix.crutchfield.com/lifestyle/2001/h4pinfirewirejack.jpeg
Now, look at the camera, and answer the same question.
If you like, I'll find the correct cable on monoprice and give you a link. I jsut need to know the connector type(s) first. .
Stuff and things
Wondertwins
Mar 06, 2010 22:53 |  #10
That is the back of my camcorder and monoprice seems to be on maintenance check for the next couple of days.
RWatkins
Mar 06, 2010 22:58 |  #11
Wondertwins wrote in post #9743677 (external link)
http://i1011.photobuck​et.com …wondertwins0/IM​G_7044.jpg (external link)
Thats a 4 pin connector.
How about your computer?
Stuff and things
Wondertwins
Mar 06, 2010 23:03 |  #12
RWatkins wrote in post #9743688 (external link)
I surprisingly do not have a fire wire connector on my computer so I need to buy a add-on card and the wire
RWatkins
Mar 06, 2010 23:06 |  #13
Wondertwins wrote in post #9743716 (external link)
Lucky for you they are cheap, so is the cable. Amazon has them for 6.00$
http://www.amazon.com …ics&qid=1267938​259&sr=8-6 (external link)
Stuff and things
Todd ­ Lambert
I don't like titles
Mar 06, 2010 23:18 |  #14
Also note that with the right software you can capture directly to your harddrive as you shoot. I had a GL2 myself and I've done this quite successfully.
Wondertwins
Mar 06, 2010 23:19 |  #15
Todd Lambert wrote in post #9743785 (external link)
what program did you use?
16,483 views & 0 likes for this thread, 7 members have posted to it.
Canon GL2 Help
1085 guests, 183 members online
