Thread started 09 Mar 2010 (Tuesday) 17:59
Where to find padding? Want to make my own bag.
Ainoko
Stupidest Question Award 2008
Mar 09, 2010 17:59 |  #1
My girlfriend wants to make a custom camera bag, and I know you can buy pre-made inserts, but they are expensive and I'd like to make some custom fit ones. I've searched around at local craft stores and hardware stores, but have not been able to find the proper padding. The type of padding I'm looking for is the kind you'd find in most camera bags. Any ideas on where to find it?
Thanks!
Full Gear List
https://photography-on-the.net …?p=4846834&post​count=1005
PBeeee
Mar 09, 2010 18:02 |  #2
Go to a camping supplier and look for high density foam sleeping pads. You can get all you need for under $20.
Ainoko
Mar 09, 2010 18:15 |  #3
PBeeee wrote in post #9762989 (external link)
Ah! Good thinking. I'll go check one out.
Full Gear List
MS-18E
Mar 09, 2010 18:25 as a reply to  @ Ainoko's post |  #4
Go to your local upholstery supply store and you can find a wide selection of foam. You want to look for closed cell PE foam, around 4lb density. The come in various thickness.
They sell them by the yard, typically pretty cheap. You can cut them to any shape you want and double or triple them up to any thickness you need.
You can also shop for different kind of fabrics there that you can sew up into sleeves or pockets to house the foam to make your padding. Then you can stitch Velcros on their edges.
DeaconG
Mar 09, 2010 19:51 |  #5
The company that comes up with pre-made Velcro padded strips for use in myriad companies' camera bags will take over the universe...
Gripped 5D Mark II & 50D|70-200 2.8 IS L|24-105 L|17-55|10-22|28 1.8|Σ 150-500|Σ 120-300 EX DG|Σ 50 1.4 EX|Σ APO 2X TC|580EXII|various other bits and pieces
"Reality holds surprises for everyone!" King Solovar, Crisis On Infinite Earths
johnnybfan
Joined Jan 2005
Mar 09, 2010 23:29 |  #6
You could get a yoga mat. It's about 1/2 as thick as the high density foam sleeping pad so it's lighter although not as rigid. I found both kinds of pads at local thrift stores. I'm going to try to make my own bag also. It does have it's challenges. :):)
jim
40D w/Grip X 2, Canon 10-22, Canon 24-70mm f2.8L
, Canon 100-400L IS, Nifty Fifty, Canon 430 EX Flash
Shadowblade
Gallery: 26 photos
Mar 10, 2010 07:31 |  #7
Find/buy/steal a few large teddy bears, rip them apart and pack the stuffing material between the inner and outer layers of the bag.
Jon
Joined Jun 2004
Mar 10, 2010 09:06 |  #8
DeaconG wrote in post #9763710 (external link)
Seen Kata's Modi-Vers insert kits? Cut the pads (in two weights) to size and use the supplied Velcro strips to assemble them.
Jon
Cocker Spaniels
MS-18E
Mar 11, 2010 11:14 |  #9
Shadowblade wrote in post #9766417 (external link)
Kidnapping teddy bears and ripping their guts out? That's just wrong
Shadowblade
Gallery: 26 photos
Mar 15, 2010 08:37 |  #10
MS-18E wrote in post #9774818 (external link)
It's called 'recycling'...
czeglin
Mar 15, 2010 08:48 |  #11
Check the link in my sig. Hopefully you're better at sewing than me!
Flickr (external link) | Gear & Feedback | DIY Padded Insert
1,643 views & 0 likes for this thread, 8 members have posted to it.
1584 guests, 139 members online
