Hi everyone,
I recently shifted to a new house out in the country. Over in the paddock next to the house is a pile of large old logs. I put out a couple of dead rabbits hoping to get a Harrier or two coming in for some photographic oppurtunities out of the 'doghouse blind'. I did see a couple feeding on the rabbits one day so the next evening set up the blind. Wouldn't you know it ........ a no show. However, all was not lost. Just before the sun went down a couple of wild cats appeared and with a lot of initial caution, started feeding on the rabbit.
1.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
2.
3.
4.
5.
6.
7.
Eventually the light became to dark to maintain decent shutterspeeds and as they were now fairly settled on the carcases I thought of trying the in-built flash. I knew the effective range of the flash was around six metres and reckoned I was at about five or so. Anyway, the AF assist beam was doing it's bit admirally to help achieve focus lock that is until it got just too dark. That's when I thought of trying to hand hold a small headlamp out the blind window to illuminate them enough to achieve focus. Intitially the cats took off in a big hurry but a few minutes later came back and soon became used to the weak headlamp beam. All very awkward of course, trying to hold the beam on them with one hand out the blind window while looking through the viewfinder and releasing the shutter with the other. All in all I thought the results weren't to bad for just the in-built flash.
This is prolly the best of the flash shots but if anyone is interested to see some of the others, just sing out.
8.
Matt.
You will be over run with kits.
