If you don't mind throwing the kit out next year when you find it's not versatile enough and upgrading to a real brand, go for it.
If on the other hand you would like your purchase to last you a while and build a bigger kit over time, you want to invest in a quality brand. This can be ABs as suggested above, or dedicated studio strobes from a brand like for example alumet, or Elinchrom (D-Lites for example).
When you eventually upgrade you can still use the units you bought as hairlights and backgroundlights and.
The quality of these brand kits are way better, light output is more consistent (no fluctuations in color temperature resulting in differently colored shots in the same shoot), and there is better availability of spare parts and modifiers (flash tubes, softboxes etc.).
Personally I'd opt (and have gone with) a "big" brand, so as to be able to slowly expand my setup over time.
Good luck deciding!
