Just wanted to see which cards you are using for your 5dmk2 to shoot video?
veronephoto Senior Member 339 posts Likes: 8 Joined Apr 2008 Location: 91 and 5 More info | Mar 10, 2010 23:00 | #1 Just wanted to see which cards you are using for your 5dmk2 to shoot video? Canon 1D Mk 4, Canon 5dmk 2, Canon 40D gripped with 28-135 IS, 70-200 F2.8 IS, 20-35 f3.5,24-105 IS,50 1.8, 85 1.2 II,100 2.8 is macro, 50 1.4, 580EX 2 speedlite/ Canon rebel xti with grip R.I.P/ backup camera- casio exilim and pentax optio S, lowepro sling, lowepro flipside 300, Pelicans 1510,1490,1080,alienbees , ALS notebook case, macbook, OPtech straps, giotto blowers, Thank you to Kingston Technologies and to Pelican Cases
dwarfcow Senior Member 640 posts Joined Feb 2010 Location: South Central, Alaska More info | Mar 10, 2010 23:08 | #2 i recommend these babies. "Evidently the photo shop at the college I go to is one of the best in the country. They actually have a handful of digital medium format cameras for students to use; Haliburtons, or hasslehoffs, or something like that."
antitera Member 119 posts Joined Nov 2008 More info | Holy cow! That's $1200 worth of CF card right there!
dwarfcow Senior Member 640 posts Joined Feb 2010 Location: South Central, Alaska More info | Mar 11, 2010 03:20 | #4 was that supposed to be a pun? "Evidently the photo shop at the college I go to is one of the best in the country. They actually have a handful of digital medium format cameras for students to use; Haliburtons, or hasslehoffs, or something like that."
yokotas13 Senior Member 558 posts Joined Oct 2006 Location: myrtle beach, south carolina More info | Mar 11, 2010 05:25 | #5 yeah, cause 64gb of photos on one card is a GREAT business decision -Grant
dwarfcow Senior Member 640 posts Joined Feb 2010 Location: South Central, Alaska More info | Mar 11, 2010 11:46 | #6 yokotas13 wrote in post #9773265 yeah, cause 64gb of photos on one card is a GREAT business decision I use about 20 4gb San Disk Ultra IIs no need for anything faster on the 5dmk2. I used extremes on my 1dmk3 if you're using 20 4gb flash cards, they are getting filled, emptied, filled emptied repeatedly (this increases wear and tear and causes failure rate). personally i have never had a CF card fail ever(knock on wood). If you buy better quality CF cards with larger capacity, you wont put as much wear on them, and have the high failures you're used to. I have washed my cards in the past multiple times, and they still worked excellent after i got done beating myself up (i replaced them before the next major event) . We replace our cards routinely (typically we only keep the fastest 6-10 cards. The only thing that has ever happened to me as far as failing is losing cf cards; it's much easier to lose a CF card than a camera body. If I have have 2 bodies, and my coworker has 2 bodies, and we never have to take the cards out of them all day, we're in a much better situation that switching multiple card that could all be in a camera bag that gets stolen, or have the cf card fall off a bridge as i'm ejecting it. If 1 out of 4 cards fails, i may have lost 75% of my pictures, but its never happened, and it wouldn't be the end of the world. "Evidently the photo shop at the college I go to is one of the best in the country. They actually have a handful of digital medium format cameras for students to use; Haliburtons, or hasslehoffs, or something like that."
dwarfcow Senior Member 640 posts Joined Feb 2010 Location: South Central, Alaska More info | btw newer cards have a higher memory wear resistance, and BBM (bad block management) than older cards and will outlast 1,000,000 read write cycles easily. "Evidently the photo shop at the college I go to is one of the best in the country. They actually have a handful of digital medium format cameras for students to use; Haliburtons, or hasslehoffs, or something like that."
ckramos Member 179 posts Joined Dec 2009 Location: Mill Creek, WA More info | Mar 11, 2010 11:57 | #8 8gb sandisk ultra which i got from Costco. 5d2 | 580ex ii | 35-70mm f3.5-4.5 | 50mm f1.4 | 17-40mm f4
Mar 11, 2010 12:23 | #9 You guys shoot video too? Canon 1D Mk 4, Canon 5dmk 2, Canon 40D gripped with 28-135 IS, 70-200 F2.8 IS, 20-35 f3.5,24-105 IS,50 1.8, 85 1.2 II,100 2.8 is macro, 50 1.4, 580EX 2 speedlite/ Canon rebel xti with grip R.I.P/ backup camera- casio exilim and pentax optio S, lowepro sling, lowepro flipside 300, Pelicans 1510,1490,1080,alienbees , ALS notebook case, macbook, OPtech straps, giotto blowers, Thank you to Kingston Technologies and to Pelican Cases
dwarfcow Senior Member 640 posts Joined Feb 2010 Location: South Central, Alaska More info | Mar 11, 2010 12:44 | #10 veronephoto wrote in post #9775207 You guys shoot video too? only when we can't capture something holding still; the only application for us has been some novelty wedding bits, and some how-to type editorials. (plus video of our daughter, psychotic drivers etc.) "Evidently the photo shop at the college I go to is one of the best in the country. They actually have a handful of digital medium format cameras for students to use; Haliburtons, or hasslehoffs, or something like that."
unbeatable Member 178 posts Joined Jun 2009 Location: Bay Area, CA More info | Mar 11, 2010 15:26 | #11 I have question can I use SanDisk Ultra II to shoot video? or I need faster card. I'm thinking to buy one from Costco since it's pretty cheap. Canon 5D MKII | 35mm f/1.4L | Canon 85mm f/1.2L II
squiLL Senior Member 667 posts Likes: 37 Joined Nov 2009 Location: Long Island, NY More info | Mar 11, 2010 15:45 | #12 two 16gb cards and a 4 gig card gets me about 2.5 hours of video easy. I will dump a card when it gets full, usually takes 15 min to empty. Mike Cassara
yokotas13 Senior Member 558 posts Joined Oct 2006 Location: myrtle beach, south carolina More info | Mar 11, 2010 15:48 | #13 dwarfcow wrote in post #9774986 if you're using 20 4gb flash cards, they are getting filled, emptied, filled emptied repeatedly (this increases wear and tear and causes failure rate). personally i have never had a CF card fail ever(knock on wood). If you buy better quality CF cards with larger capacity, you wont put as much wear on them, and have the high failures you're used to. I have washed my cards in the past multiple times, and they still worked excellent after i got done beating myself up (i replaced them before the next major event) . We replace our cards routinely (typically we only keep the fastest 6-10 cards. The only thing that has ever happened to me as far as failing is losing cf cards; it's much easier to lose a CF card than a camera body. If I have have 2 bodies, and my coworker has 2 bodies, and we never have to take the cards out of them all day, we're in a much better situation that switching multiple card that could all be in a camera bag that gets stolen, or have the cf card fall off a bridge as i'm ejecting it. If 1 out of 4 cards fails, i may have lost 75% of my pictures, but its never happened, and it wouldn't be the end of the world. http://www.engadget.com …oes-600x-the-hokey-pokey/ you may not get paid enough for it not to be the end of the world -Grant
yokotas13 Senior Member 558 posts Joined Oct 2006 Location: myrtle beach, south carolina More info | Mar 11, 2010 15:50 | #14 unbeatable wrote in post #9776524 I have question can I use SanDisk Ultra II to shoot video? or I need faster card. I'm thinking to buy one from Costco since it's pretty cheap. thats all i use, if you read a few posts up -Grant
lhughey Senior Member 650 posts Likes: 1 Joined Jun 2009 Location: DFW, TX More info | Mar 15, 2010 10:57 | #15 I've purchased expensive cards, and purchased mid range cards with good reviews. I recently purchased an 32gb A-Data 533x card for about 90.00 on Amazon. Its the best card purchase i've made. Its extremely fast and it works fine. Rob Galbraith (sp) rates it as one of the faster cards for the 5dm2 and i've seen good reviews for it. website: lhchadwick.com
| Latest registered member is SteveeY 1275 guests, 165 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
