Thread started 11 Mar 2010 (Thursday) 18:53
Flash Gel and post processing
jaswinder
Mar 11, 2010 18:53 |  #1
What kind of post processing is required when gel is used with flash to match the light in the room.
for example if in a room there is Florescent light and you use window green gel to match the light and also set correct WB in camera. Do you also correct the color in post processing ?
Canon 40D, 5DMK IV 24-70 mk II, 70-200 2.8 mk II, 100 2.8, 580 ex II
krb
Mar 11, 2010 18:55 |  #2
There's nothing different about it, just process as you normally would.
-- Ken
Gear list
jaswinder
Mar 11, 2010 19:02 as a reply to  @ krb's post |  #3
Yesterday I did a test.
Set the camera to florosecent WB and take a photo and it was blue in color and then I put the gel on the flash and took photo and it still was light blue.
Do i need to increase the temperature in ACR to make it look warmer.
krb
Mar 11, 2010 19:08 |  #4
jaswinder wrote in post #9778017 (external link)
You're the one looking at it on the monitor so you're the one who can tell what it needs. There are too many types of flourescent bulbs for a one-size-fits-all white balance solution. It gets worse if you were using a shutter speed faster than your electrical system hertz otherwise you are only getting a part of the cycle and the WB will vary from shot to shot.
-- Ken
Gear list
c2thew
Mar 12, 2010 10:51 |  #5
post picts so we can help you
Flickr (external link) |Gear|The-Digital-Picture (external link)|The $6 mic | MAGIC LANTERN (external link) | Welding Filter
Go Support Magic Lantern 2.3!!
655 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is RawBytes
1369 guests, 162 members online
