Im assuming u want a flat image of the front only and your problem is the angle of the side of the DVD player from corner to corner on the top of the DVD player?? well if thats the problem then here is the simple solution, your shooting it like a 3D object, where u want it to only appear 2D....hence your camera is not 100% level or flat with the horizon of the DVD player, which is why you are catching the top of the DVD player. You must also absorb that a lens is curved and thus even if it is positioned correctly, you still may see the top of the player because the light from the very top if bent from the outter periphery of the lens, into the center of the lens where your focal point is, and where the image is recorded. I will save you the highschool physics lesson, but an easy fix to such a problem if u cant get the lens/positioning arrangement how u want it, why not use photoshop to cut off the top of the player, thus giving you a flat surface. And if your making a book I would recommend you use a white background so it will look better with respect to your document.
I think this is what u want to accomplish with a flat 2D look even those this image was done in 3 seconds and looks horrible, if u spend more time in photoshop u can make it look nice. Your image is also not completely level, but thats an easy fix:
| Byte size: ZERO | Content warning: NOT AN IMAGE |
If this is not what u meant, then disregard this post lol
