Thread started 14 Mar 2010 (Sunday) 15:39
Help me improve my 'workflow'
sancho1983
Mar 14, 2010 15:39 |  #1
Please :)
At the moment I shoot Raw and jpeg, i come home and have a look at them with windows picture viewer, pick a few i like and edit the raws a little bit with ACR, mainly just brighten, darken. Not sure what else to do with it tbh.
Then i pick a couple of those maybe and open in PS which i sharpen. Or i'll open a couple in LightRoom and put some presets on it.
The way i see it i'm
Using Photoshop to sharpen
Using LightRoom to apply presets
Using windows viewer to view them
Using ACR to brighten/darken RAWs
Surely i could be doing it a lot smarter than that!!
Using the above method also means i keep all of my photos, even the really rubbish ones (probaby 80% :) ) so a way to delete them incorporated would be good
I like the interface of Lightroom, but don't think i'm using anywhere near its potential, with my limited time now to spend taking photographs i would like to 'streamline' as much as possible.
Any help will be greatfully received :):)
Instagram (external link)
Https://bgsweddings.co​.uk (external link)
EmmaRose
Mar 14, 2010 17:16 |  #2
Theres been a lot of threads about workflow, read through them.
Gear. Flickr. (external link)
BigStig
Some say that he is a CIA experiment that went wrong, and that he only eats cheese...
Mar 14, 2010 18:12 |  #3
You can do everything you have listed in Lightroom.
Watch some Lightroom tutorials on you tube or read on hear.
Import, rate and reject then edit all in one package.
Cheers SteveP
http://stevephilipson.​com/ (external link)
My Gear CPS Member
POTN Feedback https://photography-on-the.net …rch.php?searchi​d=25290946
tonylong
...winded
Gallery: 60 photos
Mar 14, 2010 18:16 |  #4
Lightroom and ACR (if they are the compatible versions) have the same Raw developing tools, and Lightroom has some other goodies thrown in to speed things along. Maybe if you spent some time in the Develop module to do what you currently do in ACR, you would not need ACR as an "extra step". Photoshop can easily be accessed from LR for the special needs that only PS will meet, but LR can do a whole lot that may make even Photoshop needed only occasionally.
Tony
Halliday
Mar 15, 2010 02:37 |  #5
My workflow:
1) Shoot :)
2) Download cards onto a Hyperdrive on the drive home (card reader with a laptop drive inside). That way I have the images in 2 spots, both the cards the the drive.
3) Load the images from the drive onto the computer into their own folder.
4) Import image folder into LR.
5) Use LR to,
a) make color corrections
b) cull the good from the bad
c) adjust exposure
d) output tiffs
6) Bring tiffs into PS for image correction.
7) Imports tiffs back into LR to use various presets.
8) Export images as both full-size jpegs and web-sized and sharpened jpegs.
9) Burn the whole folder to DVD.
lanceshuey.com (external link)
"Like a mechanic who forgets to wipe his hands on a shop rag and then goes home, hugs his wife, and gets a grease stain on her favorite sweater — love touches you, and marks you forever."
sancho1983
Mar 22, 2010 15:13 |  #6
BigStig wrote in post #9795992 (external link)
tonylong wrote in post #9796031 (external link)
Halliday wrote in post #9798435 (external link)
My workflow:
1) Shoot :)
5) Use LR to,
c) adjust exposure
d) output tiffs
Thanks for comments, will definitely read up on it as it sounds perfect for everything i do
tim
Light Bringer
Mar 23, 2010 05:20 |  #7
My workflow
who ­ me?
Joined Dec 2003
Mar 23, 2010 14:33 as a reply to  @ tim's post |  #8
As one who has Lightroom sitting on a shelf waiting to be installed (no time to install recently). Also not having a usable workflow due to lack of decent tools, I will be establishing a workflow that I can actually use, this may be a dumb question but....
Why convert to TIFF files?
If you try to fail and succeed, what have you really done??
tonylong
...winded
Gallery: 60 photos
Mar 23, 2010 15:48 |  #9
who me? wrote in post #9855708 (external link)
The tiff format is a "universal" image file format that has two quality levels -- 16 bit and 8 bit but is not compressed as is a jpeg. The 8 bit tiffs can be read and processed in pretty much any image editor. The 16 bit tiffs can be processed by some apps such as Photoshop while retaining more image data.
If you are shooting in Raw and need to move from a Raw processor such as DPP to an external app such as Photoshop, you will need to take one of two approaches: if you are using Photoshop CSx you can transfer the image directly into Photoshop initially skipping a "save a tiff/jpeg" step, or for any editor you do a Convert and Save to create either a tiff or jpeg so the external editor can open and process the file with all the DPP/Raw edits applied.
You should know that each Raw processor only "reads" its own Raw editing, which is why you can't make adjustments to a Raw image in, say, DPP and then open the same Raw file in Photoshop Camera Raw and see those edits applied.
If you are shooting in jpeg, there is also an advantage to saving a tiff copy if you plan to edit it: each time you save a jpeg the jpeg software performs a new conversion with at least some compression at whatever level of quality/compression it is set to. It is pretty common when you are getting started to find that an image that was in the beginning a high quality jpeg to, after a few saves, has all of a sudden become a low quality shot. So, good workflow is, once you open a jpg image into an editor, do a Save As and save a tiff for editing uses.
My normal workflow is to do as much Raw processing as possible (I use Lightroom) and then to go into Photoshop only if an image needs something my Raw processor can't provide. I tend to prefer avoiding the large tiff copies if I can:)!
Tony
tim
Light Bringer
Mar 23, 2010 17:15 |  #10
I have virtually no use for tiff files. Images that get significant editing are saved as psd files.
Halliday
Mar 23, 2010 21:37 |  #11
tonylong wrote in post #9856211 (external link)
...My normal workflow is to do as much Raw processing as possible (I use Lightroom) and then to go into Photoshop only if an image needs something my Raw processor can't provide. I tend to prefer avoiding the large tiff copies if I can:)!
I agree. There are just some fixes I can do better with PS and my wacom tablet then I can do in just LR. I do try to do as much in LR as possible thou.
2,075 views & 0 likes for this thread, 7 members have posted to it.
1065 guests, 104 members online
