How repairable is the IS system in a lens? I just sent my 17-55 off to be repaired as my camera was giving me the "Err 01" message constantly when it was attached, and the image was very jumpy during focusing.
Mar 16, 2010 14:32 | #1 How repairable is the IS system in a lens? I just sent my 17-55 off to be repaired as my camera was giving me the "Err 01" message constantly when it was attached, and the image was very jumpy during focusing. 5D Mark IV (2) l RP l 70-200mm f/2.8L IS II l Canon 24-105 l Canon 85L 1.4
DDCSD GIVIN' GOOD KARMA 13,313 posts Likes: 3 Joined Jun 2007 Location: South Dakota More info | Mar 16, 2010 14:34 | #2 Are you asking if they will be able to fix/replace the IS system? If so, the answer is yes it can be fixed. Derek
Mar 16, 2010 14:37 | #3 DDCSD wrote in post #9808852 Are you asking if they will be able to fix/replace the IS system? If so, the answer is yes it can be fixed. Yes, that's basically what I'm asking. I purchased the lens used from Adorama a month ago, and just sent it in to be repaired yesterday. I don't think they have another used 17-55 to replace it with, so I'm assuming they'll try to repair it. 5D Mark IV (2) l RP l 70-200mm f/2.8L IS II l Canon 24-105 l Canon 85L 1.4
DDCSD GIVIN' GOOD KARMA 13,313 posts Likes: 3 Joined Jun 2007 Location: South Dakota More info | Mar 16, 2010 18:29 | #4 eaglefan wrote in post #9808875 Yes, that's basically what I'm asking. I purchased the lens used from Adorama a month ago, and just sent it in to be repaired yesterday. I don't think they have another used 17-55 to replace it with, so I'm assuming they'll try to repair it.
Derek
Mar 16, 2010 18:42 | #5 DDCSD wrote in post #9810421 It's a fairly routine repair. You seem to hear of the IS going out in a fair number of 17-55's. The main reason why I sent it in was because I was routinely receiving the "Err 01 Communication between the camera and lens is faulty. Clean the lens contacts" message, and I narrowed it down to that lens. Do you know if that could be related to an IS problem? 5D Mark IV (2) l RP l 70-200mm f/2.8L IS II l Canon 24-105 l Canon 85L 1.4
440roadrunner Goldmember 1,312 posts Joined Jul 2007 More info | Mar 16, 2010 18:42 | #6 Permanent banDDCSD wrote in post #9810421 It's a fairly routine repair. You seem to hear of the IS going out in a fair number of 17-55's. Can you back that up with statistics? Hey, I'm just askin' MAYBE there's a "fair number" of 'em out there in use, too 2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
DDCSD GIVIN' GOOD KARMA 13,313 posts Likes: 3 Joined Jun 2007 Location: South Dakota More info | Mar 16, 2010 19:17 | #7 eaglefan wrote in post #9810480 The main reason why I sent it in was because I was routinely receiving the "Err 01 Communication between the camera and lens is faulty. Clean the lens contacts" message, and I narrowed it down to that lens. Do you know if that could be related to an IS problem? I honestly have absolutely no idea. 440roadrunner wrote in post #9810482 Can you back that up with statistics? Hey, I'm just askin' MAYBE there's a "fair number" of 'em out there in use, too Nope, and only Canon knows the actual fail rate. Why would I have to back up what I say that I've heard with statistics? I didn't make a claim that a high percentage of 17-55 have IS failures. I simply said that you hear about it fairly often. Yes there are a lot of them out there. I just know that I've read quite a few posts here on POTN about the IS failing on a 17-55 IS. I've read a lot more about the 17-55 IS failing than I have of all other lenses' IS failing. Derek
440roadrunner Goldmember 1,312 posts Joined Jul 2007 More info | Mar 17, 2010 13:19 | #8 Permanent banDDCSD wrote in post #9810704 I honestly have absolutely no idea. Why would I have to back up what I say that I've heard with statistics? I didn't make a claim that a high percentage of 17-55 have IS failures. I simply said that you hear about it fairly often. Yes there are a lot of them out there. That equates to a "fair number" to me, regardless of actual failure rate. I didn't say it was a bad lens. Just saying that the IS does fail on occasion and that it should be a fairly routine repair for someone that repairs lenses. Well, no, you did NOT say --in my mind-- that these lenses "fail on occasion" 2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
SMP_Homer Cream of the Crop More info | Mar 17, 2010 13:50 | #9 440roadrunner wrote in post #9815718 I was merely asking if you CAN back this up, or whether it was something you "just thought". Since I own one, I'm interested, because I have NOT "heard" about this being a problem with this lens. This isn't from Canon, but it's a very good source: EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
GolfPT Member 98 posts Joined Nov 2007 More info | The IS in my 17-55 was repaired about 3 months ago. I never thought it worked right but I didn't use it all that much. I actually had to send mine back because something was out of adjustment inside causing it to front focus terribly. When the invoice came back it said that they replaced/repaired the IS system.
jimmy-j Member 133 posts Joined Jul 2008 More info | Mar 17, 2010 14:19 | #11 i had bought a brand new 17-55 and used it for a few months and in the short time i owned it i had no issues.
DDCSD GIVIN' GOOD KARMA 13,313 posts Likes: 3 Joined Jun 2007 Location: South Dakota More info | 440roadrunner wrote in post #9815718 Well, no, you did NOT say --in my mind-- that these lenses "fail on occasion" What you put in my mind is that BY MAKING THE ORIGINAL STATEMENT is that in your opinion these lenses have a high failure rate--higher than should be expected, or you would not have mentioned it. I was merely asking if you CAN back this up, or whether it was something you "just thought". Since I own one, I'm interested, because I have NOT "heard" about this being a problem with this lens. Here is what I said. DDCSD wrote in post #9810421 It's a fairly routine repair. You seem to hear of the IS going out in a fair number of 17-55's.
Derek
mrkgoo Goldmember 2,289 posts Joined Aug 2006 More info | Mar 17, 2010 22:03 | #13 440roadrunner wrote in post #9810482 Can you back that up with statistics? Hey, I'm just askin' MAYBE there's a "fair number" of 'em out there in use, too My statistics:
johnnybfan Goldmember 1,552 posts Likes: 1 Joined Jan 2005 Location: Wyoming, MI More info | Mar 17, 2010 22:16 | #14 440roadrunner wrote in post #9815718 Well, no, you did NOT say --in my mind-- that these lenses "fail on occasion" What you put in my mind is that BY MAKING THE ORIGINAL STATEMENT is that in your opinion these lenses have a high failure rate--higher than should be expected, or you would not have mentioned it. I was merely asking if you CAN back this up, or whether it was something you "just thought". Since I own one, I'm interested, because I have NOT "heard" about this being a problem with this lens. Someone a little cranky today? jim
johnnybfan Goldmember 1,552 posts Likes: 1 Joined Jan 2005 Location: Wyoming, MI More info | Mar 17, 2010 22:17 | #15 SMP_Homer wrote in post #9815897 This isn't from Canon, but it's a very good source: http://www.lensrentals.com …11.01/lens-repair-data-35 Thanks for the link, it was very interesting. jim
| Latest registered member is griggt 666 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
