Just received my 1d MkIII, i have a sigma 10-22mm but thinking of either 17-40 or 24-70mm which 1 of the two is the better lens?
barrelwell Member 42 posts Joined Jan 2008 Location: Scotland More info | Mar 17, 2010 06:02 | #1 Just received my 1d MkIII, i have a sigma 10-22mm but thinking of either 17-40 or 24-70mm which 1 of the two is the better lens?
TheMoose Cream of the Crop 5,106 posts Likes: 1 Joined Jan 2009 More info | Mar 17, 2010 06:05 | #2 That's very subjective. One is not better than the other, they're two very different lenses. If you want a replacement for the Sigma 10-20, the 17-40 is the obvious choice. If you want something more general or long, the 24-70 is a great choice. If you want both, you could go for the 17-40 and an older 28-70 if that fits into your budget better?
actprivate Senior Member 499 posts Joined Jun 2008 Location: Australia More info | Mar 17, 2010 16:45 | #3 But if the intention is to complement 10-22, then 24-70 will make sense in my opinion because together these two give a wider focal range with no overlap. 17-40 has too much overlap with 10-22. _______________
TeamSpeed 01010100 01010011 More info | Mar 17, 2010 16:54 | #4 Sell the Sigma 10-20, get the Sigma 12-24, and then a 24-70 would be a good complement. You can keep the 10-20, but you can only use part of the focal range without vignetting. Past Equipment | My Personal Gallery
| Latest registered member is ahmed0essam 1742 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
