I plan on going whale watching at 9:30am and have no idea how to be able to shoot. I really don't want to miss taking great photos on this great trip. It is going to be a bright sunny day and any words of advise would be much appreciated. Thanks
dibbs Hatchling 2 posts Joined Mar 2010 More info | Mar 20, 2010 13:48 | #1 I plan on going whale watching at 9:30am and have no idea how to be able to shoot. I really don't want to miss taking great photos on this great trip. It is going to be a bright sunny day and any words of advise would be much appreciated. Thanks
Mar 20, 2010 16:24 | #2 If it is going to be a bright sunny day you should be able to keep the ISO fairly low. If at all possible I would probably shoot 400 iso to be able to keep the shutter speed up to be able to stop action of the whales and any other marine animals you will encounter. Camera should be on AV Servo with the drive on multiple so as long as you hold the shutter button down the camera will fire. Personally I like the AV mode where I control the aperature which I would set about f8 and hopefully the shutter speed will be above 1/1000th of a second. Try to keep the shutter speed above 1/500th because of the moving subjects and the boat rocking. Tripod would be good, sometimes can be a pain especially if you are not used to using one and there are a lot of people around. What camera and lens are you using? Hopes this helps and good luck. 1D Mark IV, 5D Mark III, 7D, 1.4X MkIII, 2X MkIII, 17-40mm L, 70-200mm f2.8 IS Mk II L, 100mm macro, 500mm f4 IS L, 24-105mm f4 L, 580 EX II, 550EX
Rayk Goldmember More info | lens "IS"? Regards Ray
halitime Goldmember 1,271 posts Likes: 19 Joined Feb 2009 Location: Lantzville B.C. Can. More info | Mar 20, 2010 18:19 | #4 CPL filter on the longest IS lens you have. Gear List : 1D MK II n,Gripped XSi,70-200 f4,300 f4 IS,Canon 24-105 f4,35 f2 IS,EF 50 1.8 MK I,EF-S 10-22,Canon 1.4 II Extender,Canon 25mm Ext Tube,YN 468/460 II,RF 602's
Thanks a million for all the advise. It is really helpful. I have a Canon Rebel XS EOS and I have two lenses - EFS 18-55 and EFS 55-250. As I am sure you can tell I am a beginner beginner and I appreciate all your feedback
KISS_freak Member 63 posts Joined Mar 2010 More info | I'm a complete newb as well, but would love to see the shots you end up with, and how it worked. I plan on taking some wildlife off a boat as well quit a bit this year. Similar gear, but lenses are IS. Canon EOS 50D, Canon 10-22 f/3.5-4.5, Canon 50 f/1.8, Sigma 24-70 f/2.8, Sigma 70-200 f/2.8 OS, 430EX II
tanner07 Senior Member 445 posts Joined Feb 2010 Location: Victoria, BC More info | Mar 20, 2010 20:02 | #7 |
kdvincent Senior Member 929 posts Likes: 27 Joined Dec 2007 Location: Gig Harbor, WA More info | Mar 22, 2010 13:46 | #8 It may be difficult for the camera to get a quick focus ona great big black mass. So shoot lotsa frames. Keith, Canon 7D, 5D, 5DMII, 30D,
TomReichner "That's what I do." 17,636 posts Gallery: 213 photos Best ofs: 2 Likes: 8390 Joined Dec 2008 Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot More info | Mar 22, 2010 14:06 | #9 I think the biggest challenge will be getting the camera low enough. The best images will be taken with the lens just a couple feet above the water's surface, yet most of the commercial whale watch boats are big and have high decks that force you to shoot from about 10 to 12 feet above the water - a rather nasty angle if you want to get some dramatic separation between a jumping whale and the water's surface. See if there's a way that someone will let you "down below" so that you can shoot thru a porthole window. That'll still be higher than you want, but much better than shooting from the deck where everybody else is shooting from. "Your" and "you're" are different words with completely different meanings - please use the correct one.
| Latest registered member was a spammer, and banned as such! 2769 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
