Thread started 20 Mar 2010 (Saturday) 20:48
How Do I WB For Infrared Photography?
taknbyd
Mar 20, 2010 20:48 |  #1
I just got myself an IR Filter for my camera that goes over my lens. I believe it's an R72 filter. Anyway, I was taking pictures with it the other day and was wondering how in the heck to be able to white balance for Infrared in camera. I have a 40D and just didn't know exactly how to do this... Thanks for helping...
Canon 40D/ EF 70-200mm IS 2.8L/ EF 50mm 1.4/ EF 28-135mm/ 430ex II x2/ 580 exII and Light Modifiers
DTBPhotography.com (external link)
Facebook (external link)
Sorarse
Mar 20, 2010 20:52 |  #2
Surely WB is for matching normal lighting in the visible spectrum. As IR is outside the visible spectrum, WB isn't going to mean an awful lot.
That's just my view and I stand to be corrected if I'm wrong.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
marco_30D
Mar 20, 2010 20:58 |  #3
You have to do a custom WB. Shoot a grass or leaves with the filter on, then use it as your custom WB. Just make sure that you fill up the whole view finder with the grass or leaves. But you still have to post process your photo to get the colors or out come you want. Hopes this help.
5DMK2 l 1DMK2 l EF 17-40 f4L l EF 24-70 f2.8L l EF 50mm f1.8 l EF 70-200mm f2.8L IS USM | EF 100mm f2.8 macro | 580ex | 580ex2 l Benro tripod w/ manfroto head l Lowepro Nature Treker AW l S21S
taknbyd
Mar 20, 2010 22:22 |  #4
Thanks Marco_30D... I didn't know if I needed to use a gray card or what... I know a lot of stuff is done in PP but I also know the a lot of people that use an IR filter do the white balance in camera. I just didn't know what to aim at to get the WB correct.
marco_30D
Mar 20, 2010 22:24 |  #5
You have to use green leaves, preferably darker greens as your white balance.
taknbyd
Mar 21, 2010 00:31 |  #6
Gotcha... Thank you so much Marco... You sir... Are AWESOME! :)
argyle
Mar 21, 2010 07:11 as a reply to  @ taknbyd's post |  #7
Setting the custom white balance is crucial, as already suggested. You should end up with an orange-tinted image (best way that I can describe it). In post, you'll need to use the channel mixer to flip the red and blue channels, then play with the saturation. There's a step-by-step on the Lifepixel site, as well as some youtube videos on processing digital IR pics...
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Mar 21, 2010 23:49 |  #8
taknbyd wrote in post #9837771 (external link)
In addition to what has been said above, blur the full-frame grass image. Blurring will help smooth out any lighter or darker area inconsistencies and help produce a frame filled with a nice, even green.
argyle wrote in post #9839874 (external link)
Not always true. Some cameras can produce an almost perfect balance. For example, my two converted cameras properly balanced produce an almost perfect B&W image. Converted is different, yes, but I also used to shoot with an unconverted Nikon Coolpix 950 using a filter and it, too, produced a well-balanced B&W image.
Another BIG mistake many people make when shooting IR is they convert their RAWs with ACR and because in ACR they come out very red, assume that is the way IR is. Not so - ACR apparently does not, or can not, shift its WB setting enough to properly WB and convert an IR image. (I use CS2, so I can't speak for ACR in CS3 or 4). Canon DPP is much better to use to convert a WB'ed IR Raw (assuming, of course it's from a canon camera.)
Website (external link) |
argyle
Mar 22, 2010 07:18 |  #9
CannedHeat wrote in post #9844880 (external link)
Well, I did say "should" :D Basing this on my experience with a LIfepixel-converted 10D. I probably should have mentioned that the foliage would look balanced, but the blue sky should/may have the orange tint to it (my IR conversion is similar to using the Hoya R72 filter, 720nm IIRC).
2,782 views & 0 likes for this thread, 5 members have posted to it.
614 guests, 125 members online
