Thread started 22 Mar 2010 (Monday) 14:15
Ebay Extension Tubes - Worth it?
Dan ­ C
Mar 22, 2010 14:15 |  #1
I was browsing eBay for extension tubes and found some from HK for under $10. They are manual focus. Are these any good or a total waste? What do I lose besides autofocus?
5D2 || Σ 50 1.4 || 24-105L || 430EX ||
Gear and Feedback || Smugmug (external link) || I prefer to receive emails instead of PMs; please send me an Email by clicking my username.
corkneyfonz
Mar 22, 2010 14:17 |  #2
On amazon UK there are some horror stories about these.
My Flickr (external link)
Dan ­ C
Mar 22, 2010 14:30 |  #3
Out of all the reviews, I only found one guy complain that he couldn't set aperture, and another couldn't remove it from his 50D. So really only 1 of 27 bad reviews.
Deep ­ Pocket
Mar 22, 2010 14:36 |  #4
You can't set aperture (forced to shoot wide open) due to the lack of electrical contact.
But there is a trick where I believe you hold down the shutter with the aperture you want then take off your lens, and then mount the tubes and lens, which makes your camera retain the aperture you specified, and repeat everytime you wish to change it again.
Inconvenient yes, so better off with the Kenko / Prooptic ones that let you set aperture, but hey, for $3 why not give it a try?
17 and learning..
Canon Rebel XSI/450D:
Sigma 30 f/1.4, EF-S 55-250mm f/4-5.6 IS, 18-55 Kit Lens
Deviantart (external link)
halitime
Mar 22, 2010 14:50 |  #5
To change the aperture you connect the lens to the body,set the aperture,remove the lens while
holding the depth of field button then put the tube back on the body with the lens.I own both styles
and will probably never use the manual ones again.
Gear List : 1D MK II n,Gripped XSi,70-200 f4,300 f4 IS,Canon 24-105 f4,35 f2 IS,EF 50 1.8 MK I,EF-S 10-22,Canon 1.4 II Extender,Canon 25mm Ext Tube,YN 468/460 II,RF 602's
http://www.flickr.com/​photos/halitime/sets/ (external link)
pturton
Joined May 2002
Mar 22, 2010 15:04 |  #6
If they physicaly fail, you could lose your lens or your camera body.
Do you really want to trust a 10 buck POS to support your $1000 lens or camera?
At least look at the Kenko tube set if you think Canon gear is too costly for your pocket.
MRagon
Joined Sep 2009
Mar 22, 2010 15:07 |  #7
I just rented a set of the kenko tubes for my first experiment in macro. I found manual focus to be no big deal and preferable. If I'd had to do all that with the aperture setting though I would've thrown them out the window. The depth of field is SO shallow using the tubes I was fiddling with aperture a lot. It's enough effort using the kenko, I can't imagine the $10 ones people describe.
Canon 7D | Canon G12 | 10-22mm f3.5-4.5 |17-55mm f2.8 IS | 24-105mm f4L IS USM | 70-200 f4L IS | Ʃ 30 f1.4 | 50mm f1.4 | 85mm f1.8 | 100mm f/2.8L IS Macro | 430EX II | LumoPro LP 160
mjHession
Gallery: 6 photos
Mar 22, 2010 15:16 as a reply to  @ MRagon's post |  #8
Can anyone offer comprehensive information on Extension tubes, (or a link), providing the different versions of them. The only Kenko's I've seen are auto focus ones (i think, they cost about $130), but I've read some posts that elude to kenkos that are manual focus but allow other controls (never seen them). And I think the $5 ebay are just plastic tubes that have no controls (contacts) at all. While there are some no-name ebays that sell for about $35, and say 'AF Confirm' and then in small print somewhere Not Auto focus, I don't even really understand what these are.
Anyone give me some information. Thanks
Primary Gear - M6 Mark II; Σ f/1.4 Trio (16, 30, 56) - Σ 150-600mm f/5 - 6.3 C
Sigma 1.4x & 2x
Full Gear List - Feedback
themadman
Mar 22, 2010 16:13 |  #9
You can set aperture... you just need to...
1. Attach lens to camera and set the aperture
2. Press and hold the DOF preview button
3. Remove lens when the DOF Preview button is pressed
4. attach extension tubes to camera
5. Attach lens to extension tubes
Problem solved.
Extension tubes are just tubes... nothing else. Kenkos have electronic contacts that allow for aperture changing and af confirm.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
hsmoscout
Mar 22, 2010 16:56 |  #10
Well they can't be a total waste for under $10, I expect you'll get what you paid for.
˙ʇsod uı ʇı xıɟ
JackLiu
Mar 22, 2010 16:58 |  #11
Your best bet is to get extension tubes manufactured by the camera co or reputable third party provider (i.e., Kenko). In the end, as stated by others, you get what you paid for!
"Love life and life will love you back. Love people and they will love you back." Arthur Rubinstein.
440roadrunner
Mar 22, 2010 17:19 |  #12
I bought a set of the import cheapies to modify for a 'scope eyepiece mount:
http://forum.manualfoc​us.org/viewtopic.php?i​d=11503 (external link)
As it worked out, I didn't have to modify the tubes at all, so they are still functional. I have only one issue CONSIDERING THE PRICE and that is they screw together and if you aren't VERY careful you can bind them up too tight, and they can be a beauotch to unscrew. They do work, you have to set the aperture manually, and they were CHEAP.
2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
Mamiya M645 1000S, 45mm 2.8, 80mm 1.9, 110mm 2.8 + 2x extender
mjHession
Gallery: 6 photos
Mar 22, 2010 17:29 |  #13
themadman wrote in post #9849262 (external link)
What exactly is 'AF confirm'? I would have thought auto focus... But then I saw an ET thats af confirm and not auto focus on ebay. View ebay listing referred to here. (external link)
Read last line.
Sigma 1.4x & 2x
440roadrunner
Mar 22, 2010 17:45 |  #14
mjHession wrote in post #9849781 (external link)
AF Confirm is a buzzword that has sprung up with aftermarket "focus chips." These are a chip designed to glue to the rear of a lens adapter, engage the electrical lens contacts of the Canon body, and activate the focus lights and beeper as you manually focus a (non AF) lens. Some of these work pretty good, some don't. Lately, there has been more and more of them become "programmable" which is an outgrowth of the original programmable chip known as the "Dandelion." I have no idea how the name came to be
http://photography.sho​p.ebay.com …onfirm%2C+chip&​_sacat=625 (external link)
photomom2one
Gallery: 61 photos
Joined Sep 2009
Mar 22, 2010 17:51 |  #15
I got some cheap ones. I liked them just fine and had no trouble releasing them from my camera or lens.
the connector got bent tho so now I can't use it, it's pretty cheaply made. I have no problem getting a new connector or just a whole new set for such a low price.
Canon 50D
50mm 1.8, 60mm, 85mm 1.8, 18-55mm, Sears 135mm
430EX
3,828 views & 0 likes for this thread, 12 members have posted to it.
1004 guests, 185 members online
