Thread started 22 Mar 2010 (Monday) 15:09
7D video picking up lens IS noise...?
njwiggit
Mar 22, 2010 15:09 |  #1
Hi
I just started trying out my 7D for video after having it a couple of months. There is a really loud noise on the video when IS is turned on on my lens. Have tried both a 70-200 and a 70-300 lens. Has anyone else experienced this? Is it a fault with my camera? The noise goes away when I turn IS off...which kind of sucks.
thanks
Nancie
ef2
Mar 22, 2010 15:10 |  #2
No, it happens because the mic is on the camera body. You'd need an external mic that's further away from the lens.
5D Mk III
Canon 580EX
Canon 16-35mm f/2.8L | 24mm f/3.5L | 50mm f/1.4 | 100mm f/2.0 | 100mm f/2.8 Macro | 135mm f/2.8 SF | 70-200mm [COLOR=black]f/2.8L IS | 70-300mm f/4.5-5.6 DO
Sigma 50mm f/1.4 EX
krb
Mar 22, 2010 15:11 |  #3
Yeah, the built-in mic will pick up noise from both the IS and the auto focus. Basically you need to either use a tripod and manual focus or you need to use an external mic.
-- Ken
Gear list
yourdoinitwrong
Mar 22, 2010 15:11 |  #4
njwiggit wrote in post #9848830 (external link)
Hi
thanks
Nancie
It's normal. Mine does it with the 24-105L IS, but not the 85mm or 70-200 f/4 non-IS. The only way to avoid this is to get an external mic, which will most likely give you better audio anyway.
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
sixsixfour
Mar 22, 2010 15:24 |  #5
the noise from the IS motor and even the AF motor can get picked up by the 7D when shooting video. I recommend going through the manual again as it specifically says that it is a normal behaviour with the on-body mic. to avoid it is to mount an externam mic as everyone here had suggested.
Canon 7D / 50D / 30D / SL1 / XT
My photography-related addiction makes a crack habit look like a fiscally responsible pasttime.
yakbut
Mar 22, 2010 15:49 as a reply to  @ sixsixfour's post |  #6
Try the 500 on the 7d for noise lol.
http://barrowdpc.com/c​pg1414/index.php (external link)
NickR
Gallery: 28 photos
Mar 23, 2010 06:16 |  #7
yakbut wrote in post #9849097 (external link)
:) I know what you mean.
I was wondering if it is possible to filter out the IS noise using Audio Editing Software ?
Nick, UK
1,706 views & 0 likes for this thread, 7 members have posted to it.
1004 guests, 184 members online
