Has anyone used the Lastolite HiLite Illuminated Background with speedlites?
http://http …om/hilite-backgrounds.php
I was wondering how it worked out and if the speedlites were powerfull enough?
cigna63 Mostly Lurking 15 posts Joined Nov 2007 Location: Rochester, NY More info | Mar 22, 2010 19:14 | #1 Has anyone used the Lastolite HiLite Illuminated Background with speedlites?
c2thew Goldmember 3,929 posts Likes: 4 Joined Aug 2008 Location: Not enough minerals. More info | Mar 22, 2010 20:02 | #2 ^ i seriously doubt that speedlights would power it, unless you had 5 Flickr
111t Senior Member 577 posts Joined Apr 2009 More info | Mar 22, 2010 21:11 | #3 That thing's just a gizmo. All you need is a white wall and a couple of studio strobes to do a 3/4 length white background. It makes more sense to me to use it as a diffuser to be used as a light source.... But it seems to me that The same white wall with a couple of studio strobes hitting it would do almost the same thing. No white walls? Why not just get a muslin? All The best!
111t Senior Member 577 posts Joined Apr 2009 More info | Mar 22, 2010 21:12 | #4 Oh and no way would it work with speedlights. All The best!
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Some people use the HiLite very successfully with Speedlight's. Robert
kuchars22 Senior Member 363 posts Joined Oct 2009 More info | Mar 28, 2010 13:15 | #6 111t wrote in post #9851166 Oh and no way would it work with speedlights. Have you got one? Have you tried it with speed lights? I have one, and it works great with speed lights, often with the one only, so long as you set it brighter than the key. I'm not going to quote how many stops, as this varies depending on how close your subject is to the HiLite. I use a 120cm octabox as a key and often quite far back from the subject. Sometimes, the fall-off to the background is quite a lot, so the speed lights need to be powered accordingly, enough stops to get 255 all round. Other times the octabox has spilled over to the background with pure white and near pure white, so the speed lights just needs a small increase to fill in the not-so-white" areas. Who cares what kit I have - it's your vision that counts! Website
sdipirro Goldmember 2,207 posts Likes: 46 Joined Dec 2005 More info | Mar 28, 2010 17:32 | #7 I normally use strobes in mine (I have two of them). However, I know people who use a single speedlight but get better results with two. Might also depend on the HiLite size. There are several sizes available now. In the 6'x7' HiLite, I get more uniform coverage with two strobes, one on each side...but in a pinch, I can get by with one. Same is probably true with speedlights. Cameras: 1DX, 1D4, 20D, 10D, S90, G2
That thing's just a gizmo. All you need is a white wall and a couple of studio strobes to do a 3/4 length white background. It makes more sense to me to use it as a diffuser to be used as a light source.... But it seems to me that The same white wall with a couple of studio strobes hitting it would do almost the same thing. No white walls? Why not just get a muslin? If I'm not mistaken in order to produce a good high-key photo you should have your subject approx. halfway between your camera and the background, then have room behind or to the side of your subject to properly light the background.
Thanks sdipirro and kuchars22 for you hands on info.
JasonW Senior Member 293 posts Joined Feb 2005 Location: Adelaide, South Australia More info | Mar 29, 2010 07:24 | #10 You can definitely do it with a single speedlite. The first group of shoots I did used a single Elinchrom BX500Ri for the main light and a 580EX-II for the HiLite:
The Speedlite was at 100% power which allowed me to get f11 at 1/200 and ISO 100 and still completely blow the background.
Thanks JasonW......that's exactly the look I want....it's good to know that I can do it with speedlights and move to studio strobes in the future.
sdipirro Goldmember 2,207 posts Likes: 46 Joined Dec 2005 More info | Mar 29, 2010 15:14 | #12 I figured I'd comment about the train and let JasonW chime in with his opinion. I bought the train for my 5'x7' HiLite and used it for a while. The train is not going to match the color of the background, and I tried lighting it separately with 1 or 2 strobes. Didn't seem to matter. I could never it right that way. I could fix it up in Photoshop, but as long as I was doing that, I asked if there were better and cheaper alternatives to the train. At the suggestions of some folks here, I bought a couple of 4'x8' sheets of this white wall board material (I'll have to go look up the exact name, if you're interested) for about $10 a sheet at Home Depot. It has a more reflective finish that I like, doesn't get folds and bends in it like the train, and it's easier to match with the background in Photoshop. So that's what I use now instead of the train. Cameras: 1DX, 1D4, 20D, 10D, S90, G2
munzzzzzzz Senior Member 591 posts Joined Feb 2009 Location: SE WI More info | Mar 29, 2010 15:39 | #13 Since we're on the topic of the HiLite, can someone who has one explain what it's made of? I've seen the pictures but have never seen one in person and am curious. Is the front just your basic softbox diffuser fabric, and what is the back made of? 6D | 40mm f/2.8 | 50mm f/1.4 | 70-200mm f/4L IS | 580EXII | 2x PCB Einstein | Various Modifiers
sdipirro Goldmember 2,207 posts Likes: 46 Joined Dec 2005 More info | Mar 29, 2010 15:41 | #14 It's called white tile board, and in looking for the correct name, I found an older HiLite thread where JasonW not only said he used the train but showed the technique for blending the train with the background in Photoshop. It was his technique that I applied. I'm not sure if Jason is still using the train, but he seemed pretty happy with it a while back. My problems began when I folded it up to store it and could never really get the folds out. Your mileage may vary. Cameras: 1DX, 1D4, 20D, 10D, S90, G2
sdipirro Goldmember 2,207 posts Likes: 46 Joined Dec 2005 More info | Mar 29, 2010 15:45 | #15 munzzzzzzz wrote in post #9894850 Since we're on the topic of the HiLite, can someone who has one explain what it's made of? I've seen the pictures but have never seen one in person and am curious. Is the front just your basic softbox diffuser fabric, and what is the back made of? They're certainly not cheap, and I wonder if something like that couldn't be a DIY project if you didn't need to move it around. Yeah, the front seems like typical diffuser fabric. You can even use the thing as a giant softbox. The back is a heavier, non-reflective black material. It's maybe a foot or so deep with zippers around all four edges so you can put flashes/strobes anywhere and use whatever orientation you like. Of course, a big advantage of the real HiLite is being able to fold it up and stick it in its carrying bag like a reflector. Cameras: 1DX, 1D4, 20D, 10D, S90, G2
| Latest registered member is Marcsaa 1221 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
