When I saw this post, it reminded me of a device I bought with my first Video Camera. It was a Slide and Film adapter, which screwed onto the front of the camera lens. The adapter is a Canon DP-10.
My Video Camera got stolen, but the adapter did not and has sat in my darkroom, unused ever since. I used the insurance money to upgrade to a much lighter camera, which had a different lens. I had never used the adapter more than a few times, so decided a lighter camera was more important.
The adapter has similarities to the Xtendaslide and came with 2 different ends that could be swapped. One was for slides and the other for negatives. The camera had an invert video switch for use with negatives. The DP-10 has a very thick/heavy lens at the camera end of the tube.
The method of use was to screw it onto the camera, insert a slide and point the end at a light source.
I dug out the DP-10, which seems to have about a 60mm thread, pointed the G3 into the lens end and placed a slide in the slide adapter. I then pointed the unit at a piece of white styrofoam. The G3 was connected to the PC in Capture mode. Sunlight through the window was regularly fading behind clouds and the image on screen faded at the same time. Eventually I grabbed a simple torch and pointed it at the styrofoam. The resulting image can be seen at:
http://community.webshots.com/user/imbrucew
in the Hobbies album.
As a comparison, I have also posted the same slide, scanned by my Nikon Coolscan III, film and slide scanner. In both cases I used the maximum resolution the equipment had to offer, which means the CSIII has 3690x2436 pixels, compared to the G3s 2272x1704.
The CSIII scan is unaltered. The G3 image was a bit blue, so I have adjusted the colors a bit.
The Exif data should be embedded in the posted image, but in summary; I used tungsten White Balance with Exposure mode = Av, set at f8.0, to help with focus problems. Shutter speed is 1s.
The PC Capture software is a real dog to use and I spend most of my time trying to work out how to manual focus using this software. I came to the conclusion that it will not let you manual focus. When I changed the White balance it seemed to trigger some auto action that gave me close to correct focus. I note the EXIF data indicates that the distance is 2.13m, which is certainly not the length of the CP-10. The lens in the CP-10 must be the explanation. The CP-10 length is about 165mm.
I believe the results of the G3 are quite good, although they are more contrasty than the CSIII. If I spent more time on the lighting I could probably have improved the contrast, by using a more diffused light. Also, if I had chosen a custom white balance I could probably have solved the blue color cast. I do not have a lens adapter, so I just used a piece of plumbing PVC to improve the interface between the G3 and the DP-10. Very crude.
Bruce
