Alex (NewphotoMan) and I got together today and it gave me the opportunity to test out the 70-200 2.8L IS version 1 versus the version 2. All shots shot with 1D Mark III, handheld, IS on on both. The first set of tests is the 200mm focal length. I will be adding 70mm test shots that were taken inside a bookstore in a bit. Other focal lengths will have to be re-done.
Absolutely nothing has been done to these images except conversion from RAW to JPEG, and obvious crops in the crop images. Everyone should realize that some sharpening should usually be applied, but for pure testing purposes, all settings have been zeroed out.
First set of shots are the 70-200 2.8 IS
ISO 400 - 200mm, f/2.8, 1/125th
Crop
ISO 400, 200mm, f/4, 1/80th
Crop
This set is the 70-200 2.8 IS II
ISO 400, 200mm, f/2.8, 1/125th
Crop
Crop
