Thread started 24 Mar 2010 (Wednesday) 07:03
Exactly which Kenko 1.4X or 1.5X TC doesn't prevent autofocus with XXD bodies?
Maxdave
Gallery: 49 photos
Mar 24, 2010 07:03 |  #1
I am confused about the characteristics of the various Kenko 1.4X teleconvertors, of which I believe there are at least three ....
I already have a Kenko 1.4X Teleplus Pro 300 DG (model name taken from the box) which works very well with my Canon 70-200mm f/4. Autofocus is retained and IQ is quite good.
I just acquired a Canon 100-400mm f/4.5-5.6. The Kenko gives adequate (for my purposes) IQ with this lens also, but kills autofocus on both my 40D and 50D. I understand this occurs because the Kenko communicates to the camera that the effective aperture of the lens has dropped below f/5.6.
My understanding is that Kenko markets (or used to market) a different model teleconvertor of approximately 1.4X or 1.5X magnification and does not stop the cameras from autofocusing with lens of aperture less than f/5.6.
I know about the taping trick I could use with my current teleconvertor, but, to be honest, I would rather buy another teleconvertor that did not require taping especially for the 100-400mm, if autofocus could be retained and the level of IQ did not appreciately suffer as compared to my existing Kenko model.
Would an owner (or someone in the know) let me know which exact model Kenko teleconvertor I should get for my 100-400mm (and where to get it, if possible).
Thanks!!
Maxdave
5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS​-E2,2x580EX,430EX,90EX,​EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&​Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
gcogger
Joined Mar 2003
Mar 24, 2010 07:09 |  #2
I'm afraid I don't understand why you want to spend money on another (inferior) teleconverter rather than just using a bit of tape? It's not that the camera is supposed to AF with the cheap teleconverter, just that it doesn't know not to (the same as when using tape on the Pro version).
Graeme
My galleries (external link)
5Dmaniac
Mar 24, 2010 07:17 |  #3
If you want a good TC (like your Kenko Pro), then you will have to tape the three pins. Just go ahead and do it.
halitime
Mar 24, 2010 07:32 |  #4
I use a Tamron 1.4X C-AF1 MC4 which doesn't report and gives great results Only has 8 pins.
BH price $129
Gear List : 1D MK II n,Gripped XSi,70-200 f4,300 f4 IS,Canon 24-105 f4,35 f2 IS,EF 50 1.8 MK I,EF-S 10-22,Canon 1.4 II Extender,Canon 25mm Ext Tube,YN 468/460 II,RF 602's
http://www.flickr.com/​photos/halitime/sets/ (external link)
photobitz
PlatinumMeasure​baiter
Mar 24, 2010 09:20 |  #5
I had a Kenko 1.5x teleplus SHQ which didn't report. It was pretty crap compared to the new ones though.
Dan
My gear | Me on Flickr (external link)
Wilt
Mar 24, 2010 11:43 |  #6
The cheap teleconvertors generally do NOT report their presence, but the optics are inferior!
The good teleconvertors DO report their presence, but the optics are superior! The 'solution' is simply to tape the pins so their presence is not reported to the body; that will allow the body to TRY to focus even with f/8 lens, but that does NOT mean that the lens will SUCCEED in achieving focus...and you could burn out an AF motor from it trying and trying and trying!!!
1.5x convertors are all 'the cheap ones'. Some 1.4x convertors are cheap, some are good quality.
https://photography-on-the.net ….php?p=287408&p​ostcount=4
Maxdave
Gallery: 49 photos
Mar 25, 2010 07:59 as a reply to  @ Wilt's post |  #7
Thank you all for your information and opinions.
Maxdave
vmaidens
Gallery: 40 photos
Mar 25, 2010 08:52 |  #8
You don't tape all the pins.
If you're looking at it facing your on the body, it'll be the first three pins on the left.
http://www.vincemaiden​sphotography.com (external link)
http://twitter.com/VMa​idensPhoto (external link)
http://500px.com/Vince​Maidens (external link)
Lowner
"I'm the original idiot"
Mar 25, 2010 10:32 as a reply to  @ vmaidens's post |  #9
Theres absolutely no downside to taping the pins. It's extremely quick and easy to do and if for any reason it ever needs to be removed, then that equally is a simple 30 second job.
I suppose Canon had to create the artificial AF/no AF point somewhere, otherwise AF motors could in theory be overworked, but I've not noticed my 100-400 working particularly hard or long to achieve focus since taping the pins but before I taped them it just point blank refused to play ball.
Richard
440roadrunner
Mar 25, 2010 11:18 |  #10
My experience is completely different. Neither my "white" Tamron, nor my Kenco are reliable, nor fast, on my 100-400L on any body I own. They both hunt unpredictably for focus
I've made plastic washers, one of which isolates the converter from the camera, one of which isolates the "magic pins" and I often completely disconnect the converter for use with a couple of old manual lenses I have.
I actually don't know why I don't just sell 'em.
2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
Mamiya M645 1000S, 45mm 2.8, 80mm 1.9, 110mm 2.8 + 2x extender
2,808 views & 0 likes for this thread, 9 members have posted to it.
1040 guests, 106 members online
