Thread started 24 Mar 2010 (Wednesday) 12:14
b-grip quick once over.... (neck strap replacement)
Mark1
Mar 24, 2010 12:14 |  #1
I got the b-grip (www.bgrip.com (external link)) to try out because of my disdain of neck straps. I have been shooting for almost 25 years and have never even come close to dropping something. So for me they are way more of a hindrance than anything else. I will use a neck strap for theme parks and such but even then it is wrapped around my wrist. I have no problem holding the camera in my hand all day. But I may just be used to it.
I stumbled on the b-grip as it was featured on the front page of Adorama on one visit. I noted it, but moved on to what I was looking for. About a week later I remembered it for some reason, and went for a closer look. (http://www.adorama.com​/CZPOP9.html (external link)) At $50 it seemed kinda high. But as I looked into other systems of the same kind, the b-grip stood out, and was cheaper than most of the others.
Well it arrived yesterday, so this is a quick once over. Next week however I will probably have it on for about 16 hours a day, So look for a full review in a week and a half.
It is made out of high quality ABS. So it should last forever. If feels very solid but yet light weight. It is very comfortable to wear. Though very awkward at first, you get used to it rather quickly. In fact I am wearing it as I type this, with my 50D with the 70-200 2.8 mounted.
You thread your belt through it and wear it like a hand gun holster. I however,I have decided to use a second belt so I can position it as needed on the fly with out having to take off my belt to be able to move it to the back when needed.
It attaches to the camera side with a mount very much like a tripod quick release plate. It is a proprietary measurement. It is just a tad smaller than a RC-2 size plate. Had they thought and made it the same size, it would have been better as it could do double duty. There is a lil arm on the plate that flips forward. This keeps the camera from falling forward when you extend it then set the camera down. Nice feature but if you have a heavy lens it does not help at all.
The belt side is obviously like the other half of the tripod QR. There is a lever you have to move 90 degrees to mount or unmount the camera. So it is a 2 hand operation to mount it or unmount it. HOWEVER there is a secondary catch that keeps the camera from falling out when the lever is moved. You have to lift and rotate the camera forward for it to come out. It takes a few seconds the first few times to disengage the camera when you first use it. But practice a few times and in 10 minutes, how you need to move the camera becomes second nature.
The latch system is rated for 70 pounds. WAY more than any camera setup you will be hand holding. Even if you have to 1200 5.6!!! (36.4 pounds + camera). And I feel confident in its ability to hold. I have not tried jumping fences like in the videos on the bgrip website. But I feel at first look they were not exaggerating anything.
It extends down for about 4-5 inches. This keeps the lens up off your leg so there is no rubbing as you walk. It keeps the camera more straight down than falling over. If you can understand my poor description
It also comes with a rain cover. They call it waterproof. But it is just the same nylon that they make jackets out of. I guess it will work as you make a mad dash for cover when it rains. But if you have time to pull it out and put it on.... you have time to simply find shelter.
It also comes with a safety strap. This thing does not inspire confidence. But I think it will give you a extra second to catch the camera of it falls. And if it does fall it will most likely be your fault not the b-grip. It is just a quick release that you pinch. with cords on each side. One that will go on your strap bung on the camera. The other to the b-grip. I may not install this.
As I mentioned this is just a quick once over for now. I will end up living with this for a week straight next week. I will up date then on actual usage.
Mark1
Mar 24, 2010 12:31 |  #2
I just tried the b-grip mount in my $7.99 travel tripod, and it fits it perfectly.
I travel with cheep tripods incase I have to leave it behind for some reason. Also I don't mind having a $7.99 tripod half buried in mud on a shoot as much as a $399 one.
rang
Mar 24, 2010 13:36 |  #3
Mark1 wrote in post #9862079 (external link)
$7.99?
How many inches tall is it??
$7.99???
Jeez...you sure it has *3...legs* for that much money
:lol:
Just kidding you...I've never seen one that cheap.
Lotsa stuff, running outta room and a wife...I keep looking at her and wondering??? :lol:
Mark1
Mar 24, 2010 19:13 |  #4
It is a Micro Center Special. They are about 5 foot useable hight. I get one when needed. It has been a while since they were on sale, I should have stocked up. But, Yes, $7.99. It is totaly a throw away pod. That said, it is very stable, extremely so for that price range. I have a strange adversion to putting my good tripod in 3 feet of water and mud. Once I found these, I get them to basicaly use and toss. I will hose it down and reuse it. But I definatley do not take care of it in any way. I have a $14.99 scorce for when Micro Center is out.
Jonathan ­ Taylor
Mar 24, 2010 19:45 |  #5
glad you hear you like it with the 70-200 mounted, but do you have a grip on your 50D? how do you think it would fare if you had a gripped or pro body? would that affect its, well, effectiveness?
5DII, 7D, 20-35 2.8L, 35L, 40 Pancake, 50 1.4, 85 1.8, 135 2.0L, 300 f/4L IS, 580EXII, Alien Bees, Bags & Bags & More Bags.
A man is drowning. You can save him, or photograph him. Which lens do you use?
www.Jonathan-Taylor-Photography.com (external link)- www.Facebook.com/Jonat​hanTaylorPhotography - (external link)www.ModelMayhem.com/Jo​nathanTaylor (external link)
Jonathan ­ Taylor
Mar 24, 2010 19:49 |  #6
actually, i found my answer.
the last half of this video demoed it:
http://www.youtube.com …Ezf8ysc&feature​=quicklist (external link)
Mark1
Mar 24, 2010 22:06 |  #7
Actually my 50 is gripped. I never take it off so I forget about it. It is fine so far.
I can give a better review after next week.
Jonathan ­ Taylor
Mar 24, 2010 22:17 |  #8
cant wait!
ps - where in md are you?
Mark1
Mar 24, 2010 22:41 |  #9
Frederick.
Jonathan ­ Taylor
Mar 24, 2010 23:38 |  #10
Nifty :-D
I'm about 15 minutes south of Leesburg. We're practically neighbors :-P
Back on topic...I just ordered a B-Grip for my second body (XTi w/ 17-50), and an R-Strap for my main (Gripped 7D, 70-200, 580II). I think this will make for a nice combo, but we'll find out!
kingdavidd
Joined Jun 2010
Feb 19, 2011 22:19 |  #11
Hi everyone,
I just came across the b-grip from a photo magazine. How is your experience so far? How are you liking it?
Thanks!
7D | EF 24-105L f4 | Sigma 10-20 f4-5.6 | Tamron 18-250 f3.5-6.3 | 270 EX | Slik Sprint Pro ii | Gitzo GT1541 with Manfrotto Head 496rc2
wish list: 70-200 f2.8 IS ii
SnlpeR
Feb 19, 2011 22:32 as a reply to  @ kingdavidd's post |  #12
its very awkward when you put it on a gripped body
the quick release mount seems to be made of hard plastic?
Mark1
Feb 21, 2011 09:55 |  #13
I still use the heck out of it. My only negative about it really, is it takes 2 hands to mount and unmount it from the clip. It is not built in a way you can "leave it open" like some other brands such as the spyder. But other than that I have no problems with it at all. It holds everything quite stable from just a body and a 50 1.8 to a body, grip, and a 70-200 2.8.
Not sure what SnlpeR means by awkward. It works quite well. But I would suggest getting a second belt to use it on. When used on the same belt as your pants, you lock it into the one space between belt loops. That may be file depending on what you are doing. But if you put it on a second belt you can move it to any position around your body. Plus it tends to chew up the top of the belt. So buy a belt just for it and you will not mess up your good belt.
I wish they sold just the cleat so I can leave them on things and not have to sawap them out.
rowbow
1 post
Joined Jan 2012
Jan 17, 2012 05:21 |  #14
Hi I have been using my B-grip that is supplied with a good strong belt it's the latest model that only has one release clip, the system is very comfortable, the only problem I have is finding a ball head that the quick release will fit on, any one found a head that fits.
Regards
John (UK)
Mark1
Jan 17, 2012 13:06 |  #15
I am thinking of moveing to the new model. The update to it looks like it will be worth it.
The best I can tell is the new one fits the RC-2 style quick release. The old one was only about 3 mm to narrow to fit. So I am sure they made a lil adjustment rather that re-engineer a different mount.
---- Fount their compatibility chart.... http://bgrip.com …atibility_table​_lores.jpg (external link)
5,462 views & 0 likes for this thread, 7 members have posted to it.
1067 guests, 104 members online
