Thread started 24 Mar 2010 (Wednesday) 14:35
anyone use Blue / Yellow polarizer?
360°
Mar 24, 2010 14:35 |  #1
a local camera store was clearing out a bunch of stuff and i picked up a Blue / Yellow polarizer for 2 dollars....
seems to just add a tint of blue or yellow depending on how you rotate it
anyone know what this could be used for?
List Of Gear:Canon 5D Mark III---1D Mark III---Canon 5D Mark II---Canon 85 F1.2--Canon 100mm f2.8 macro---Canon 24-70 F2.8--- Canon 70-200 F2.8 IS II---Canon 300mm F2.8---Bunch of pocketwizards
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 24, 2010 23:05 |  #2
Try it on something that will reflect like a buildings windows or a car.
I have the set that I occasionally used for a special effect with film. With PS, I don't find much use for it anymore.
rral22
Mar 25, 2010 07:56 |  #3
360° wrote in post #9862876 (external link)
I think it's for adding a bit of blue or yellow depending on how you rotate it. ;)
I don't know how well it works as a polarizer, and that is an effect that it is very hard to match with post processing, but color changes are easy to accomplish in post. I still use a polarizer. I never use filters for the color effects any more.
Play with it and see if you like it.
argyle
Mar 26, 2010 06:32 as a reply to  @ rral22's post |  #4
It may possibly be a bit similar to the Singh-Ray Gold-N-Blue polarizer in terms of effect. If so, you *may* need to make a few adjustments in post (WB and Tint)...what you see in the VF may not be what you see in the captured image. Shooting with film is another story...what you see is what you get and no other adjustments would be necessary. But with digital, you most likely will need to make the adjustments. For $2, its worth playing with. Here's a link to the S-R Gold-N-Blue polarizer with regard to RAW adjustments:
Gold-N-Blue Polarizer RAW Adjustments (external link)
360°
Mar 26, 2010 12:33 |  #5
ok so i tried it out... it turns all reflections off non metallic surfaces either yellow or blue depending on how you turn it
1,104 views & 0 likes for this thread, 4 members have posted to it.
2858 guests, 157 members online
