Thread started 24 Mar 2010 (Wednesday) 17:10
85mm f/1.8 and fringing
HSK
Mar 24, 2010 17:10 |  #1
Hi guys, I just have a quick question regarding the 85mm f/1.8 - Does it tend to pick up a lot of 'fringing' at a wide aperture?
I know most lenses probably pick up some fringing, especially in areas of contrast...I just seem to be noticing it a lot more with my lens I bought recently, compared to other lenses I have. Maybe even in places I wouldn't consider to be of great contrast. The purple fringing is more prominent.
It's probably just me over analysing, or just a normal characteristic of the lens.
But just in case, I would like your opinions.
A couple of full size samples:-
http://kalay.co.uk/mis​c/IMG_2960.jpg (external link)
http://kalay.co.uk/mis​c/IMG_2928.JPG (external link)
*link fixed
bohdank
Mar 24, 2010 18:26 |  #2
This is a baffling lens. I have shots that should have produced fringing such as backlit portraits with the background blown out and no fringing shows up along the hairline. Other times, it shows up at any opportunity. Exposure helps (don't err on overexposure) but that's about all I can advise.
First shot.... I assume you are referring to the dried branches at the bottom of the image. Ya. Not something I would have expected.
Second link doesn't work.
mrkgoo
Mar 24, 2010 18:29 |  #3
Totally expected. If shot wide open, this lens can produce some of the most obvious purple fringing.
That said, sometimes it doesn't show up as badly. I tend to shoot it at f/2.0 or smaller to reduce this, but really, it's just part of this lens wide open.
I might look up some of my own f/1.8 shots for comparison.
snyderman
Mar 24, 2010 18:33 |  #4
Yes. Most of my work with the 85mm f/1.8 was shooting high school basketball at f/2.0. The purple fringing seemed most obvious where white met black or another dark color. Not so much on the edges of the white, but where the white met another dark color.
Only under good lighting conditions and a perfect exposure did I see absolutely no purple fringing. I'm kind of surprised your outdoor shot picked up that much. It's definitely noticeable at the 100%, but much less on the web-sized image.
dave
Canon 5D2 > 35L-85L-135L
mrkgoo
Mar 24, 2010 18:39 |  #5
Here you go.
100% crop (screen grabs, click to see full down-sized image):
IMAGE: http://grab.by/grabs/87bc9e157c33ad1e09ac34677f0dcd50.png
IMAGE LINK: http://grab.by …a4deb42dadd2a56​9243a5.png  (external link)
IMAGE: http://grab.by/grabs/425ef94c3d89ee7d6b1db1d2e4f43f8a.png
IMAGE LINK: http://grab.by …e41fb14550710ce​7bb5e4.png  (external link)
HSK
Mar 24, 2010 19:09 |  #6
Hmm bohdank I actually know what you mean, I take some shots and it will be fine, but here and there (like the samples given) I get a couple which display prominent fringing.
Thank you guys for your replies and the additional samples.
htpc
Joined Sep 2009
Mar 24, 2010 21:31 as a reply to  @ HSK's post |  #7
i feel for your purple fringing concerns....
I was somewhat upset my 85L 1.2 also shows lots of purple fringing (and CA)....
I wonder if this is an issue that could be minimized if its sent back for adjustment.
ie. maybe some lenses have alignment of lenses that could be improved.
Thoughts anyone? for 1.8 and 1.2 lenses like the two 85 mm's....can purple fringing and/or Chromatic aberation be improved by sending lenses in for work at canon?
(attached files are 85mm L at 1.2 and note neither is fixable via DPP CA adjustments for this lense on my 7D)
7D / 24LII f1.4 / 85L f1.2 / 135L f2 / T 11-16 f2.8 / EF-S 17-55 f2.8 IS / 1.4x TC II / 580EX II / GT2541 w Acrotech ... Want 200L f2!
Austin.Manny
Mar 24, 2010 21:34 |  #8
Lightroom -> Develop -> Detail -> Defringe -> All Edges = Solution :)
1D Mk III | 450D Gripped | Σ 30 f/1.4 | 85 f/1.8 | 18-55 IS
Canon 430exIII | LumoPro LP180 | Yongnuo YN-460 |
RF-603
htpc
Joined Sep 2009
Mar 24, 2010 21:37 as a reply to  @ htpc's post |  #9
one more example of purple fringe plus CA (note green on right, purple on left) at 1.2
is this a bad copy of the lense or is this within expectations?
stickshift
Mar 24, 2010 21:40 |  #10
Austin.Manny wrote in post #9865405 (external link)
Doesn't help for longitudinal CAs (bokeh fringing).
7D, 5D mark II
17-40, 24-70 II, 70-200 f/4 IS, Zeiss 35/2, 85/1.8, 135/2, 400/5.6
Erik_L
Mar 24, 2010 22:07 |  #11
And I really want to buy this lens! should I let this stop me?
Canon EOS 1D III
Manfrotto 190X Pro B w/324RC2 "Action Head" | Canon 580EX II
Sigma 20 f/1.8 | Canon 35 f/1.4 L | Sigma 50 f/1.4 | Sigma 85 f/1.4 | Canon 135 f/2 L
Flick (external link)r
themadman
Mar 24, 2010 22:11 |  #12
Erik_L wrote in post #9865623 (external link)
I'd wait on the Sigma 85 1.4 if you don't NEED this lens right now.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
stickshift
Mar 24, 2010 22:25 |  #13
themadman wrote in post #9865646 (external link)
The 85/1.4 is not going to be cheap. The 85/1.8 screams value IMO.
7D, 5D mark II
nicksan
Man I Like to Fart
Mar 24, 2010 22:30 |  #14
Ouch.
I have noticed that when lenses are out of whack, it can have worse fringing. I noticed the amount change my a marked amount when dialing in different MFA amounts.
justinalamode
Mar 24, 2010 23:45 |  #15
I, too, have experienced fringing with the 85mm f/1.8
| Canon EOS 5D Mark II w/ BG-E6| Canon G11 | Canon 24-70 f/2.8L | Σ 50 f/1.4
3,747 views & 0 likes for this thread, 21 members have posted to it.
971 guests, 184 members online
