Thread started 24 Mar 2010 (Wednesday) 19:49
When does one use ND filters and why?
peterbj7
Location: A Caribbean island in Belize and occasionally UK
Mar 24, 2010 19:49 |  #1
The title says it all. Is it just a way of cutting down on the light reaching the camera? If so I can see why it might be used in very bright places, but I don't see why they're used in normal photography. Can an expert please enlighten me? I know from other posts that many other people share my lack of understanding of the use of these filters.
5D & 7D (both gripped), 24-105L, 100-400L, 15-85, 50 f1.8, Tamron 28-75, Sigma 12-24, G10, EX-Z55 & U/W housing, A1+10 lenses, tripods, lighting gear, etc. etc.
"I prefer radio to television. The pictures are better"
theextremist04
Mar 24, 2010 22:50 |  #2
There are a couple of reasons. The first is when you're trying to get a long exposure and it's bright out. The second big reason is if you want a narrow DOF when it's bright out- it means that you don't need to stop down to get the appropriate aperture.
A lot of landscape photographers also used graduated ND filters to make sure the entire scene is exposed correctly- if you don't have one the sky often tends to be overexposed, especially during sunrises/sunsets.
-Michael
Gear - Flickr (external link) - Website (external link) - Facebook (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 24, 2010 22:56 |  #3
Using ND Filter to create special effects: An introductory guide
TooManyShots
Mar 24, 2010 22:57 |  #4
You can use one during a very bright day in order to control the highlight. As long as you can still maintain faster enough shutter speed with it, you can use it on your walk around lens. The main purpose is to doing a long exposure shot when motion blur is desirable such as capture flowing water or a rough sea, during early evening lighting condition. Depending at what stops the ND filter is rated. At 3 stops, you can get a 20 second exposure shot at F16 under ISO200 during early evening. At 10 stops, you can do the same thing properly during the middle of the day. When you capture moving water at 20 second exposure or slower, the water would become smooth and fog like. The effect is surreal...
One Imaging Photography (external link) and my Flickr (external link)
dugcross
Mar 25, 2010 22:31 as a reply to  @ TooManyShots's post |  #5
Any waterfall photo where the water is smooth and milky are usually the result of a shot taken with a ND filter.
Doug Cross
Graphic Designer and Photographer
www.crossphotographics​.com (external link)
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Mar 26, 2010 00:15 |  #6
I have had some good luck with a 9 stop ND filter for long exposure shots in the daytime.
5dMk II
f/22
37sec
41mm (natural)
5dMk II
f/22
80sec
95mm (natural)
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
ckckevin
Mar 26, 2010 00:28 |  #7
although i've known most of it already, this is still a great read.
Kevin life= learning
500D, Canon 10-22mm, Tamron 17-50mm 2.8, Canon 60 macro, Canon 85mm 1.8, Sigma 8mm 3.5, Sigma 30mm 1.4, Sigma 50-150mm 2.8, Kenko SP300 1.4x, efs extension tubes, 580EX, and lens that i don't like
jra
Mar 26, 2010 05:38 |  #8
Another application would be on a bright sunny day and you're using a strobe to balance out the sun. You need to get your shutter speed down low enough to allow it to sync properly.
birdfromboat
Location: somewhere in Oregon trying to keep this laptop dry
Mar 26, 2010 13:30 |  #9
Radtech has inspired me with that shot. this forum always makes me think in a different direction-thanks.
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Looking through a glass un-yun
JeffreyO
Mar 27, 2010 13:35 as a reply to  @ birdfromboat's post |  #10
I used one for this so I could get a slow enough shutter speed on a bouquet of flowers in the sun.
XSi with grip, Sigma 18-55 f/3.5-5.6, Sigma 28-70 f/2.8, Canon 100 f/2.8 macro, old but great Canon 300 f/4 L, 430 EX II, Quantaray 900W, broken tripods, White Lightnings, many accessories--former pro film, quit, now back into it for fun
Flickr (external link) - Picture Zealot blog (external link) (Old)
1,244 views & 0 likes for this thread, 10 members have posted to it.
2858 guests, 157 members online
