Thread started 25 Mar 2010 (Thursday) 14:29
Camera Flash Brakets
duckiller01
Mar 25, 2010 14:29 |  #1
I will shooting a family members sweet sixteen and need some help with a flash bracket. I've shot family parties in the past and dislike the way the pictures come out when I shoot in portrait, I expect a bracket that keeps the flash above the camera to help.
Looked at RRS and CB but they both offer several options... options are great but sometimes they just confuse people (me).
Camera is either my 1DMKIII or my 5DMKI and the flash is a 580EXII. I may have use for this bracket down the road so I dont mind buying something solid... but it needs to be realistic.
Also, what lenses are most popular for Wedding Photog's? I think a sweet sixteen would be the same style shoot.
Thanks in Advance!!
Robert
5DMKIII ll 35L ll 24-70L ll 70-200L II ll 2x TC ll 1.4x TC ll 580EXII
CosmoKid
Mar 25, 2010 14:49 |  #2
are you using direct flash with the speed light on camera?
your 70-200 is good. other lenses would be the 24-70.
Joe- 2 bodies, L 2.8 zoom trilogy and a couple of primes
iRocktheShot.com (external link) - Portfolio (external link)
Gear/Feedback
Facebook "Fan" Page (external link) -
duckiller01
Mar 25, 2010 14:58 as a reply to  @ CosmoKid's post |  #3
I have been but that's what I want to get away from... hence the thread title.
CosmoKid
Mar 25, 2010 15:06 |  #4
ew. snarky. actually your thread title just states "camera flash brackets".
there are other ways to avoid direct flash when your camera is on-board. on-board is different than direct.
you could use a homemade bounce card or one of the products from lumipro or Demb. even if you decide on a bracket you should avoid bare, direct flash, and one of those products, or a home made solution, would help you.
Gear/Feedback
duckiller01
Mar 25, 2010 15:20 as a reply to  @ CosmoKid's post |  #5
I see where you are coming from. I never used the term "direct" so I thought you were referring to it's mounting position.
I have a Sto-fen as well as the Honlphoto 8" Speed Snoot/ Reflector
CosmoKid
Mar 25, 2010 16:13 |  #6
the sto-fen is strictly a bounce aid. The Honlphoto reflector I have no experience with but it seems to be like many of the other reflectors out there. it wont do you much good in portrait orientation.
adding a bracket would be a start, yes. stroboframe makes a decent bracket that is affordable.
This is the one I was looking at. I do not have a lot of use for one so the Stroboframe was a good compromise for price and performance.
http://www.bhphotovide​o.com …l_Folding_Flip_​Flash.html (external link)
It is designed for both types of body sizes too.
My buddy is a full time wedding photog and uses this one:
http://www.bhphotovide​o.com …RO_E_Camera_Rot​ation.html (external link)
And I believe this is the cord you need...
Flash Zebra Cords (external link)
I use this system for the flash:
Lumiquest pro Max (external link)
It has a main piece called the 80/20 which gives 80% bounce and 20% fill. If you can't bounce, there are multiple inserts to direct it all forward and it softens. It comes with a few of these...white, gold and silver.
Gear/Feedback
tim
Light Bringer
Mar 25, 2010 16:15 |  #7
Shoot landscape and crop. I'm not kidding.
duckiller01
Mar 28, 2010 12:17 as a reply to  @ tim's post |  #8
Dont you loose a lot of resolution for the larger prints? It make a ton of sense but I'd definitely have to work at breaking that habit of flipping the camera.
Wilt
Mar 28, 2010 14:21 |  #9
Since you're not a pro, the expense of Newton or CB or the even more expensive RRS is unwarranted. You might give a look at this one, but it will not accomodate you 1D ...
http://www.tiffen.com …roboframe&itemn​um=310-900 (external link)
As for lenses for your FF, something with 28mm works nicely without worry about inducing perspective distortion when you are too close to the subjects.
trudgy
Mar 28, 2010 16:00 |  #10
thread I started and came to the conlusion the Newton was the way to go if you care to read:
https://photography-on-the.net/forum/showthre​ad.php?t=840709
Canon 7D gripped - Canon 10-22mm 3.5/4.5- Canon 24-70mm 2.8 L - Metz’s Mecablitz 58 AF-1 - Canon 580EX II - Presslite Vertex - Qbox 24
Wilt
Mar 28, 2010 16:42 |  #11
trudgy wrote in post #9888165 (external link)
You made a good choice (it was not obvious that was the final choice, from that other thread, as you only had concluded with the mention of correspondence with Robert Newton)
tim
Light Bringer
Mar 28, 2010 16:42 |  #12
duckiller01 wrote in post #9887010 (external link)
With the 7D I still have 3500 or pixels or so, by 2300 or so, which is plenty for a 12" print. I rarely have them printed larger than 7" anyway.
Savas ­ K
Mar 28, 2010 16:57 |  #13
It looks like the flash is no higher over the camera than when mounted to the hot shoe when using the Newton FR2. Isn't the main idea of a flash bracket to get the flash some 18" over the camera?
Wilt
Mar 28, 2010 17:11 |  #14
Savas K wrote in post #9888464 (external link)
The Newton + Canon OC-E2 cord puts the hotshoe flash higher by 3cm, compared to the 40D hotshoe placement.
The purpose of the bracket is primarily to keep the flash CENTERED ABOVE the lens axis, regardless of camera orientation. If you want the flash even higher, there is an optional extension to raise the flash higher.
Savas ­ K
Mar 29, 2010 15:23 |  #15
Thanks. Looks great.
2,260 views & 0 likes for this thread, 12 members have posted to it.
1249 guests, 151 members online
